Sorry that doesn't work. Its only the admin account. No other accounts are affected, @DirectAdmin Support is there a script to fix the admin permissions at admin level?as root issue the following commands:
chown root:root /usr/bin/sudo
chmod 4755 /usr/bin/sudo
That doesn't sound right. The message from sudo literally tells you that /usr/bin/sudo is either not owned by root or doesn't have the setuid bit on. The commands I gave do exactly that. If you are saying that the admin user can't do sudo then that is another issue. I would expect a completely different error message.Sorry that doesn't work. Its only the admin account. No other accounts are affected, @DirectAdmin Support is there a script to fix the admin permissions at admin level?
I know, i am going mad. All other users can sudo only the admin account cannot.That doesn't sound right. The message from sudo literally tells you that /usr/bin/sudo is either not owned by root or doesn't have the setuid bit on. The commands I gave do exactly that. If you are saying that the admin user can't do sudo then that is another issue. I would expect a completely different error message.
-rwsr-xr-x. 1 nobody nobody 165656 Apr 24 2020 /usr/bin/sudoShow us the following:
* output from "ls -l /usr/bin/sudo"
* show the exact command you are trying to issue and the error
Depending on the error that is output, we might need the contents of your /etc/sudoers file or at least certain lines within it.
Not that I am aware ofThat is a problem, it should be owned by root. Did you map the user/group nobody to uid/gid 0?
As root user I get the following:That is a problem, it should be owned by root. Did you map the user/group nobody to uid/gid 0?
I get the following:Sudo will allow you to run applications in privileged mode. The way it is allowed to run something as root, is because the sudo binary is owned by the user root (uid 0) and the setuid bit enabled ( s instead of x in user part of the perms). The 's' bit says to run this as the owner which should be root.
It is possible that it is still owned by "root" and just displaying "nobody" due to the order of the entries in your /etc/passwd.
As the user what do you see when you do:
ls -ln /usr/bin/sudo
The "n" added to ls will display the user and group id numbers and not try to map it to a user.
Are you using something other than /etc/passwd for users? Like AD or LDAP?
I see this if I cat the /etc/passwdSudo will allow you to run applications in privileged mode. The way it is allowed to run something as root, is because the sudo binary is owned by the user root (uid 0) and the setuid bit enabled ( s instead of x in user part of the perms). The 's' bit says to run this as the owner which should be root.
Okay, how do i turn that off? We need the admin user to be able to execute sudo. I didn't turn this on so i'm sure as to what has happened?OK, I think I see your issue. Your admin user is going through a jailed shell therefore the /usr/bin/sudo may not be the same /usr/bin/sudo you are looking at as root (no jailed shell). Typically jailed shells will have their own environment/filesystem and may prevent running anything as root since you really want that user jailed.
Sorry I am very new to linux, how would i do that?change the shell for admin from /usr/bin/jailshell to something like /bin/sh or /bin/bash or another shell you prefer. Just make sure that the shell exists (in some cases /bin/bash doesn't exist but /usr/bin/bash will). After that you would need to log back in as admin and try again.
Thank you for this. I am still getting the same errorPersonally I open /etc/passwd with vi, modify that record, save it and exit. As a beginner vi is very daunting. You can do this:
vi /etc/passwd
use the arrow keys to move the cursor to the line that reads:
admin:x:1002:1003::/home/admin:/usr/bin/jailshell
when the cursor is over the slash in /usr/bin/jailshell you can type a capital 'D', it should erase from the cursor to the end of the line
type a lowercase 'a', this will all you to append to that line starting at the current position from there you can type the shell (i.e. /bin/sh)
when complete, hit the Esc key, this brings you out of edit mode. Now type ":x" without the quotes. The colon will display on the bottom left of the window and the x tells vi to save the edited file and exit.
Unfortunately DirectAdmin doesn't have an easy method for modifying /etc/passwd.
One more way to do this is if you do:
grep jailshell /etc/passwd
and there is ONLY one entry, and /usr/bin/bash exists, then you can do this:
perl -pi -e 's#/usr/bin/jailshell#/bin/bash#g' /etc/passwd
Just make sure that you change /bin/bash to a shell that already exists on your system.
