Warning: Undefined array key "version"
Strator
Just a quick heads up that I'm seeing a minor error on Custombuild 2's "CustomBuild Functions" page (/CMD_PLUGINS_ADMIN/custombuild/custom_build_functions.html)
Warning: Undefined array key "version" in /usr/local/directadmin/plugins/custombuild/admin/tabs/custom_build_block.php on line 4
Most likely an incompatibility with either php 7.4 or php 8. Thanks as always!
Hi Richard,
Yes, on a fresh server with AlmaLinux, DirectAdmin and Custombuild. Nothing special installed.
Do you know what I can do to fix this?
Hello Tvandegeijn.
No I'm sorry, I thought this was fixed in an updated build version as I did not encounter the issue on the Centos 8 install and I didn't see anybody reporting it since many months anymore. (Which does not always proove something is fixed by the way).
So that's why I wondered. Must be something wrong if that is on a fresh install.
Maybe something in the custombuild must be fixed then. Maybe @smtalk can have a look at this.
Same problem for me, your suggestion Brent did not resolve the issue for me
Custombuild 2.0.0 (rev: 2891)
AlmaLinux 8
DA Server version 1.641
For what it's worth, after 18 months, I am still seeing this. Plugin version was (and has been) 1.0.37.
Odd that nobody posted their php versions. php 8.0X for me.
Soon CustomBuild won't be PHP-dependent and it'll be part of DA (not a plugin).
