How to add custom option to Admin Dashboard
alrnetwork
Europe UTC+2
Hi all,
Very new to DirectAdmin, but super, SUPER impressed with it so far.
I was wondering how I can create my own custom button / link within the Admin interface, to be shown to admins only. At this point, it simply needs to be a button which acts as a hyperlink (I have Grafana set up for performance monitoring and want a quick way for admins to access it).
As the Grafana interface is running on the host, I would like it to be able to collect the existing host url (without port number). I'm happy to design a little icon, is there any specific format? PNG etc? (see attached mock-up)
I was digging around on the net, but couldn't find an answer, or maybe just not searching well.
Thanks in advance!
Hello and welcome to the forum. Also Welcome to Directadmin. You most likely haven't received a response because no one else is doing what you want done. No you did not do anything wrong. The forum is a Community run forum. Support does visit here but mostly its User run.
You might look here
Other main links to see
Docs
Version info
How to use the Frontend
Feature request
Hi @bdacus01,
Thanks for taking time to respond, however, I'm afraid the linked articles aren't what I need. I'm very surprised that there's no desire to add options to the dashboard, other than as plugins / modules etc.
Even trying to work out where those icons are coming from would be a start.
You might post here https://forum.directadmin.com/forums/skin-programming.42/
I thought you wanted to add a custom link and a icon to the Admin evo frontend?
Did you check this out?
Do you mean like where in the theme its stored? I think it's closed source.
if you need the company to add something you would post that in the Feedback section. Link provided.
@bdacus01 - Indeed I do, but the function listed there for adding the icon, only adds it as a "Feature Set", not a "feature". Thus, it only shows in a specific layout, when the icon grid is the layout I require.
I've added my post to the section you mentioned!
Thanks again.
