Mirror files-de down
Erulezz
--2021-03-06 10:28:53-- https://files-de.directadmin.com/services/custombuild/2.0/custombuild.tar.gz
Resolving files-de.directadmin.com (files-de.directadmin.com)... 2a01:4f8:10a:6db::4, 46.4.143.169
Connecting to files-de.directadmin.com (files-de.directadmin.com)|2a01:4f8:10a:6db::4|:443... connected.
ERROR: The certificate of 'files-de.directadmin.com' is not trusted.
ERROR: The certificate of 'files-de.directadmin.com' hasn't got a known issuer.
The certificate's owner does not match hostname 'files-de.directadmin.com'
Fileserver might be down, using the backup file server..
For all maybe a extra extended documentations DA and certificates, also tls versions and cipher for al services ports and ipv4 ipv6 also hostname, and domainnames.
So if someone has such to solve it themselves.
Also a kind of test script / diagnose build in DA GUI panel for such things to check could be handy? ;)
I think something is wrong with IPv6;
That's why I receive the certificate is not trusted error. Can I force CustomBuild to only use IPv4?
Maybe on the help direct admin, itself a test section for DA admin to test online global their servers then with settings in that test optimized for DA PANEL and servers, so only DA using servers and domains could be tested.
Kind of online ssllabs, dns , dkim, whatever tests special for DA licensed Servers only, that as a special service (free? ) with links to docs and help files if advice or errors.
Such things could make DA stand out of other control Panels ;)
But i don't know costs for traffic, some country's have cheap traffic.
I think something is wrong with the IPv6 setup of this mirror;
You can try for time being other servers, ok this is sg for ipv6 is ok grade b for example?
This one in UK is IPv4 only
# ping6 files-de.directadmin.com
PING files-de.directadmin.com(2a01:4f8:10a:6db::4 (2a01:4f8:10a:6db::4)) 56 data bytes
64 bytes from 2a01:4f8:10a:6db::4 (2a01:4f8:10a:6db::4): icmp_seq=1 ttl=51 time=15.0 ms
64 bytes from 2a01:4f8:10a:6db::4 (2a01:4f8:10a:6db::4): icmp_seq=2 ttl=51 time=15.0 ms
64 bytes from 2a01:4f8:10a:6db::4 (2a01:4f8:10a:6db::4): icmp_seq=3 ttl=51 time=14.9 ms
64 bytes from 2a01:4f8:10a:6db::4 (2a01:4f8:10a:6db::4): icmp_seq=4 ttl=51 time=14.9 ms
rtt min/avg/max/mdev = 14.965/15.023/15.080/0.156 ms
1​
2a01:4f8:10a:6db:0:0:0:4
Certificate not valid for domain name
Sat, 06 Mar 2021 11:41:35 UTC
Duration: 11.796 sec
Yes.... pinging works.... but there is something wrong with the TLS certificate for IPv6, please check SSLLabs;
Or this (Dutch) test: https://internet.nl/site/files-de.directadmin.com/1141515/
And that's why I, and everyone else using the DE mirror over IPv6, receive this error:
Fixed, thank you for the report!
--2021-03-06 19:22:10-- https://files-de.directadmin.com/services/custombuild/2.0/custombuild.tar.gz
Connecting to files-de.directadmin.com (files-de.directadmin.com)|2a01:4f8:10a:6db::4|:443... failed: No route to host.
Connecting to files-de.directadmin.com (files-de.directadmin.com)|46.4.143.169|:443... connected.
It stops after
8. kvm.martynas.it 0.0% 7 2.9 3.0 2.9 3.2 0.1
9. ???
It's working again ? A while back there was also this issue with IPv6 on this mirror.. just curious.... what was the issue / fix?
It was an improperly configured gateway for IPv6 there. Happened after OS upgrade&reboot.
