Disconnected from my local internet connection
pixGT
Hello
When I'm in the mid of DA installation I got disconnected from my local internet connection. How to see the installation process again. Please advise me.
If something goes wrong - I will reinstall OS and then run DA install again.
Ii was few times, when DA installs and don't give me admin login/pass and asks to reinstall some component, then I repair and finish installation. But each this non ideal install gives me, a lot of BUGs in future.
So my advice - just reinstall all from scratch.
Next time you do a fresh installation on a linux server, use the screen command.
This way if you loose the internet connection, after it comes back, you can login via ssh again, connect to the screen and see what is happening.
