Solved ProFTPD issue with sftp
bibiugly
Vietnam
Today, I install mod_sftp into ProFTPD with the following instructions:
The installation went well (figure 1).
However, at the telnet step, everything is not correct (Figure 2).
And then I try to use FileZilla to connect sftp to port 23 and it doesn't work.
I also turned off Firewall and telnet to port 23 using Ping.eu tool, port 23 is open.
Hope I will receive your support.
I love DirectAdmin.
It looks like it's listening for regular FTP connections on port 23 somehow, odd. Can you share the content of /etc/proftpd.sftp.conf?
It is set up to listen on port 23. If you have telnet installed on you server might be a conflict.
./build set ftpd proftpd
./build proftpd
mkdir -p custom/proftpd/conf
wget -O custom/proftpd/configure.proftpd http://files.directadmin.com/services/all/sftp/configure.proftpd.sftp
wget -O custom/proftpd/conf/proftpd.conf http://files.directadmin.com/services/all/sftp/proftpd.conf
chmod 755 custom/proftpd/configure.proftpd
wget -O /etc/proftpd.sftp.conf http://files.directadmin.com/services/all/sftp/proftpd.sftp.conf
./build proftpd
Make sure you dont have Port 23 set in SSHd config either its not needed.
I have to eat be back later to help you more @bibiugly
This is content in file, everything is default:
<IfModule mod_sftp.c>
<VirtualHost 0.0.0.0>
    # The SFTP configuration
    Port 23
    AuthUserFile    /etc/proftpd.passwd
    TransferLog      /var/log/proftpd/xferlog.legacy
    ExtendedLog     /var/log/proftpd/103.110.86.87.bytes WRITE,READ userlog
    SFTPEngine on
    SFTPLog /var/log/proftpd/sftp.log
    SFTPHostKey /etc/ssh/ssh_host_rsa_key
    SFTPAuthorizedUserKeys file:~/.sftp/authorized_keys
    SFTPClientMatch ".*WS_FTP.*" channelWindowSize 1GB    #WS_FTP initial window size
    SFTPClientMatch ".*ClientSftp" sftpProtocolVersion 3  #CuteFTPPro8
    SFTPClientMatch ".*WinSCP.*" sftpProtocolVersion 3    #upload/download fix for WinSCP
    SFTPClientMatch ".*SecureBlackbox.*" sftpProtocolVersion 3
    SFTPClientMatch "1.0" sftpProtocolVersion 3 channelWindowSize 1GB
    SFTPClientMatch ".*J2SSH_Maverick.*" channelWindowSize 1GB
    SFTPClientMatch ".*WeOnlyDo.*" sftpProtocolVersion 3 channelWindowSize 1GB
    SFTPClientMatch ".*EldoS.SSHBlackbox.3.*" sftpProtocolVersion 3 channelWindowSize 1GB
    SFTPClientMatch ".*IP.Works.*" channelWindowSize 1GB
</VirtualHost>
</IfModule>
./build proftpd
./build proftpd
I'm sure port 23 doesn't have any service yet.
I'll try your code and get back to you soon.
I tried your code, but things still don't work out yet.
Below are all of my ports in use:
[root@labda custombuild]# netstat -tulpn
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
tcp        0      0 0.0.0.0:2210            0.0.0.0:*               LISTEN      24096/sshd
tcp        0      0 0.0.0.0:7080            0.0.0.0:*               LISTEN      17055/openlitespeed
tcp        0      0 0.0.0.0:587             0.0.0.0:*               LISTEN      14289/exim
tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      17055/openlitespeed
tcp        0      0 0.0.0.0:465             0.0.0.0:*               LISTEN      14289/exim
tcp        0      0 103.110.86.XX:53        0.0.0.0:*               LISTEN      23329/named
tcp        0      0 127.0.0.1:53            0.0.0.0:*               LISTEN      23329/named
tcp        0      0 0.0.0.0:25              0.0.0.0:*               LISTEN      14289/exim
tcp        0      0 127.0.0.1:953           0.0.0.0:*               LISTEN      23329/named
tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      17055/openlitespeed
tcp6       0      0 :::2210                 :::*                    LISTEN      24096/sshd
tcp6       0      0 :::3306                 :::*                    LISTEN      1078/mysqld
tcp6       0      0 :::2222                 :::*                    LISTEN      13574/directadmin
tcp6       0      0 :::21                   :::*                    LISTEN      16360/proftpd: (acc
tcp6       0      0 :::23                   :::*                    LISTEN      16360/proftpd: (acc
tcp6       0      0 ::1:953                 :::*                    LISTEN      23329/named
udp        0      0 0.0.0.0:443             0.0.0.0:*                           17055/openlitespeed
udp        0      0 0.0.0.0:43790           0.0.0.0:*                           17068/openlitespeed
udp        0      0 0.0.0.0:46940           0.0.0.0:*                           17067/openlitespeed
udp        0      0 0.0.0.0:7080            0.0.0.0:*                           17055/openlitespeed
udp        0      0 103.110.86.XX:53        0.0.0.0:*                           23329/named
udp        0      0 127.0.0.1:53            0.0.0.0:*                           23329/named
udp        0      0 127.0.0.1:323           0.0.0.0:*                           566/chronyd
udp6       0      0 ::1:323                 :::*                                566/chronyd
Thank you for your enthusiasm. :love:
Odd... It is proftpd running on 23, so that's something. What does "service proftpd status" say (after a restart of proftpd), that sometimes contains sefull info
Here's all the information you need, hopefully you can find it:
[root@labda custombuild]# service proftpd status -l
Redirecting to /bin/systemctl status  -l proftpd.service
● proftpd.service - ProFTPD FTP Server
   Loaded: loaded (/etc/systemd/system/proftpd.service; enabled; vendor preset: disabled)
   Active: active (running) since Fri 2021-03-19 12:17:35 +07; 50min ago
  Process: 16358 ExecStart=/usr/sbin/proftpd $PROFTPD_OPTIONS (code=exited, status=0/SUCCESS)
  Process: 16356 ExecStartPre=/usr/bin/mkdir -p /var/run/proftpd (code=exited, status=0/SUCCESS)
Main PID: 16360 (proftpd)
   CGroup: /system.slice/proftpd.service
           └─16360 proftpd: (accepting connections
Mar 19 12:17:35 labda.domain.com systemd[1]: Stopped ProFTPD FTP Server.
Mar 19 12:17:35 labda.domain.com systemd[1]: Starting ProFTPD FTP Server...
Mar 19 12:17:35 labda.domain.com proftpd[16358]: 2021-03-19 12:17:35,102 labda.domain.com proftpd[16358]: fatal: SFTPHostKey: unable to check '/etc/ssh/ssh_host_rsa_key': No such file or directory on line 13 of '/etc/proftpd.sftp.conf'
Mar 19 12:17:35 labda.domain.com proftpd[16358]: 2021-03-19 12:17:35,102 labda.domain.com proftpd[16358]: warning: unable to include '/etc/proftpd.sftp.conf': Operation not permitted
Mar 19 12:17:35 labda.domain.com proftpd[16358]: 2021-03-19 12:17:35,109 labda.domain.com proftpd[16358] 127.0.0.1: mod_sftp/1.0.1: Server 'ProFTPd': ListOptions directive is not supported by mod_sftp, and will be ignored
Mar 19 12:17:35 labda.domain.com systemd[1]: Started ProFTPD FTP Server.
I have found the answer for myself. After running the following two commands everything worked perfectly:
ssh-keygen -f /etc/ssh/ssh_host_rsa_key -N '' -t rsa
chmod 600 /etc/ssh/ssh_host_rsa_key
service proftpd restart
Glad you found it!
