What better configuration for SEO better access speed to the hosted sites?
cabn12
1- OpenLightSpeed
2- Apache and:
apache + php-fpm
Ioucube
Opache
3- Extend connections in php-fpm
vi /usr/local/directadmin/conf/directadmin.conf
php_fpm_max_children_default=1000
./build rewrite_confs
Sorry:
1- OpenLightSpeed or,
2- Apache and:
apache + php-fpm
Ioucube
Opache
These types of question cannot not be answered in a paint can approach.
We would to know a lot more about your system.
In general OLS is faster than Apache. However it is not full functionality as LS. OLS is essentially a carrot to hope you will buy LS.
2- Apache and:
apache + php-fpm
Ioucube
Opache
Apache option 2 is fine and well used and tested.
I would only do this if you are sure of your resources on your server. If not you could overload the server if you dont do the proper calculations
If You can work without htaccess - better will be nginx+php-fpm+Opcache
for shared hosting I'm using or nginx_apache Php-Fpm Opcache Mariadb 10.4-10.5
or cloudlinux with its lsphp
1- OpenLightSpeed
2- Apache and:
apache + php-fpm
Ioucube
Opache
./build rewrite_confs. for more you can reach us at Wild Creek Studio
These are reasonable performance optimizations, but I would not set php_fpm_max_children_default=1000 without checking the server’s RAM and workload first. A high PHP FPM worker limit can increase concurrent connections, but it can also consume a lot of memory and potentially crash the server.
OpenLiteSpeed is a good option for performance, while Apache with PHP FPM, OPcache, and proper PHP FPM tuning can also work well. After changing the configuration, run ./build rewrite_confs and monitor CPU, RAM, PHP FPM processes, response times, and errors to make sure the changes are actually improving performance.
