Requests to DA get timed out
ASghostKI
I just setup a new server on BuyVM and installed DA, everything seems to work, beside this problem where while connecting to DA control panel some requests to the DA (backend) gets timed out sometimes: " net::ERR_CONNECTION_TIMED_OUT"
not all request times out, and the one that time out they go through after a retry (DA might retry by itself or I'll have to refresh)
here is a screenshot of the Network tab on Chrome. (I was just opening DA and logged in and navigated on the menus) and got some of the requests times out)
PS: this happens only on the DA panel, I installed a WordPress site on this and tested it none of it's requests has timed out.
There is nothing on DA error.log beside some old Can't connect to SSL errors;
I don't know where to check for errors or how to debug this, any help would be appreciated guys
May you check if pre-release has the same issue?
I couldn't check that.
But I think that's not the problem because I found out that this only happens with my Home network, when I try with my phone's 4G I don't get any timeouts at all.
That's weird tbh, I couldn't find a reason why, the traceroute shows nothing, and also as I said not all requests fails just some of them and they go through after a retry either by DA itself or after a refresh
