Solved exim not start
eldorado
i I couldn't sent email from squirrelMail, therefore i search net and found this commands:
i go to :
/usr/local/directadmin/custombuild
and then i use this commands:
./build dovecot
./build todovecot
./build exim
but, exim not start and this error occurred:
Exim configuration error in line 1 of /etc/exim.srs.conf:
main option "srs_config" unknown
how can i fix this problem.
my centos version 6.7
Try this.
./build set exim yes
./build set eximconf yes
./build exim
./build exim_conf
That should take care of the problem.
It should be default at 4.5, but one never knows, it's better to be sure indeed.
+1 for stopping squirrelmail and start using Roundcube.
Try this.
./build exim
./build exim_conf
i try this but when i use this command:
./build exim
this error appears:
Cannot find /usr/include/db.h.  Please install db.h
yum install db4-devel perl-ExtUtils-Embed
when i try to use this command:
this error appears:
Loaded plugins: fastestmirror
Setting up Install Process
Loading mirror speeds from cached hostfile
YumRepo Error: All mirror URLs are not using ftp, http[s] or file.
 Eg. Invalid release/repo/arch combination/
removing mirrorlist with no valid mirrors: /var/cache/yum/i386/6/centos-sclo-rh/mirrorlist.txt
Error: Cannot find a valid baseurl for repo: centos-sclo-rh
i search the net, and understand that i must change yum repo.
i change baseurl in CentOS-Base.repo to:
baseurl=http://vault.centos.org/6.7/os/$basearch
but when i save this file and use this commands:
yum clean all
yum update
this error appears:
Setting up Update Process
That is because Centos 6 is EOL for some time.
Try this:
curl https://www.getpagespeed.com/files/centos6-eol.repo --output /etc/yum.repos.d/CentOS-Base.repo
After that, again yum clean all and then
Otherwise, pay for and use cloudlinux or even better, get a new server/vps with Centos 7.9 and transfer everything.
Try this:
i use this , but not working for me
i search and find this :
echo “https://vault.centos.org/6.10/os/x86_64/” > /var/cache/yum/x86_64/6/base/mirrorlist.txt
echo “http://vault.centos.org/6.10/extras/x86_64/” > /var/cache/yum/x86_64/6/extras/mirrorlist.txt
echo “http://vault.centos.org/6.10/updates/x86_64/” > /var/cache/yum/x86_64/6/updates/mirrorlist.txt
echo “http://vault.centos.org/6.10/sclo/x86_64/rh” > /var/cache/yum/x86_64/6/centos-sclo-rh/mirrorlist.txt
echo “http://vault.centos.org/6.10/sclo/x86_64/sclo” > /var/cache/yum/x86_64/6/centos-sclo-sclo/mirrorlist.txt
i use above commands but instead of 6.10 i use 6.7 and instead of x86_64 i use i386
therefor i use this:
echo “https://vault.centos.org/6.7/os/i386/” > /var/cache/yum/i386/6/base/mirrorlist.txt
echo “http://vault.centos.org/6.7/extras/i386/” > /var/cache/yum/i386/6/extras/mirrorlist.txt
echo “http://vault.centos.org/6.7/updates/i386/” > /var/cache/yum/i386/6/updates/mirrorlist.txt
echo “http://vault.centos.org/6.7/sclo/i386/rh” > /var/cache/yum/i386/6/centos-sclo-rh/mirrorlist.txt
echo “http://vault.centos.org/6.710/sclo/i386/sclo” > /var/cache/yum/i386/6/centos-sclo-sclo/mirrorlist.txt
but for 4th command,
echo “http://vault.centos.org/6.7/sclo/i386/rh” > /var/cache/yum/x86_64/6/centos-sclo-rh/mirrorlist.txt
an error occurred again
i understand that there isn't any file in this url->http://vault.centos.org/6.7/sclo/i386/rh
therefore i use that same url for this line:
echo “http://vault.centos.org/6.7/sclo/x86_64/rh” > /var/cache/yum/x86_64/6/centos-sclo-rh/mirrorlist.txt
then i use
yum update
yum update successfully.
and then i try to install
new problem occurred:
No package db4-devel available.
No package perl-ExtUtils-Embed available.
Those packages are maybe in the EPEL or PowerTools repository.
yum repolist
for
i use this command:
wget https://public-yum.oracle.com/public-yum-ol6.repo -O /etc/yum.repos.d/public-yum-ol6.repo
yum install --nogpgcheck -y db4-devel
*important: if you are not able to connect to oracle , please use [shecan]
i install db4-devel successfully
now i must install perl-ExtUtils-Embed :( :)
for install ExtUtils-Embed i use this:
wget http://files1.directadmin.com/services/all/perl_modules/ExtUtils-Embed-1.14.tar.gz
tar xvzf ExtUtils-Embed-1.14.tar.gz
cd ExtUtils-Embed-1.14
perl Makefile.PL
make
make install
but in line 4 an error occurred. so i should install perl-devel and perl-ExtUtils-MakeMaker. so i use this commands:
yum install --nogpgcheck  perl-devel
yum install --nogpgcheck  perl-ExtUtils-MakeMaker
*if don't use --nogpgcheck another error occurred. so use this option.
after this, all of dependencies are installed successfully.
now i go to /usr/local/directadmin/custombuild and again run this command:
./build exim
the exim successfully run. :)
i test squirrelMail, i can send email from squirrelMail, but i can't receive emalis. :(
Being able to send, but not receive, can be caused by another issue.
Again, stop using Squirrelmail and install Roundcube. I liked Squirrel more too, but... well....
You have to check the logs anyway why you can't receive mails, or error notices from mail programs.
We can't do anything for you without error notices to start some place.
when i send an email from gmail to myserver mail, this error appears:
The response from the remote server was:
550 authentication required
i also install Roundcube , but it is like Squirrelmail, both have that problem and not receive any email and error 550 authentication appears.
Do you use external MX addresses for the domain you are sending to?
If not. Check your MX page and make sure that the option "Use this server to handle my emails." is checked for that domain.
the checkbox was unchecked
when i check it, new error occurred when i sent email:
550 No such recipient here
That would mean the email address does not exist. There are some topics about this on the forum, you might find a solution in there if the email address does exist.
thanks.
[solve]
mx Record was the reason :)
i must check the local checkbox
with best regards.
