Hello, I wasn't sure where to put this as I couldn't find a category for Litespeed, so hopefully this is ok.
Now that the official release is out, I'm trying to figure out what is the correct way to update from 5.4. I don't see the file in versions.txt like one would for OLS. So I don't know what the correct terms to use would be for updating a custom_versions.txt (as mentioned here).
I did see that litespeed says to update via command:
But not sure though if that will cause problems if it is something that needs to be handled by custombuild rather directly updating.
I also tried updating the build to see if it would show up but that didn't do anything.
Has anyone updated to LS 6.0? How did you do it?
/usr/local/lsws/admin/misc/lsup.sh -f -v 6.0 |
