Pacific Spirit
I am using WHMCS on directadmin and the installation was perfectly! Unfortunately due a issue in that directadmin system is the PHP version selection completely buggy and completely wrong coded by directadmin, also a lot of programs are bugged anyway, WHMCS asked me to set in the cronjobs. I asked WHMCS and they say that the problem occurs in DirectAdmin, why won't the PHP in damn way not change, because if I set it to PHP 7.3 or higher, WHMCS still says: Your PHP version 7.2.34 is supported by WHMCS. this is so crap by directadmin that WHMCS cannot locate the correct PHP version.
Secondary is indeed the cronjob. I have a Warning my by automatically runs of the cron but I have following the full troubleshoot of WHMCS with this dump cronjob, for some reason it just stopped and this is very annoying. Any idea why DA messing up WHMCS? Is DA so bad coded or so? I don't hope but it looks like.
| Cron Invocation Frequency |
