Custombuild problem with RHEL 8.3
dmtinc
Chile
Hi!
After some problems installing modsecurity on RHEL 8.3, I think something is missing:
* This system has been installed today only directadmin, nothing more configured.
For example this part of custombuild:
  if [ ! -e /usr/include/lua.h ] && [ ! -e /usr/local/include/lua.h ]; then
                if [ "${OS}" != "FreeBSD" ] && [ ! -e /etc/debian_version ]; then
                        if [ "${OS_CENTOS_VER}" = "8" ]; then
                                if [ "${CLOUDLINUX_OPT}" = "yes" ]; then
                                        yum -y install lua-devel --enablerepo=cloudlinux-PowerTools
                                elif [ -e /etc/yum.repos.d/CentOS-PowerTools.repo ] && grep -m1 -q '\[PowerTools\]' /etc/yum.repos.d/CentOS-PowerTools.repo; then
                                        yum -y install lua-devel --enablerepo=PowerTools
                                elif [ -e /etc/yum.repos.d/oracle-linux-ol8.repo ]; then
                                        yum -y install lua-devel --enablerepo=ol8_codeready_builder
                                else
                                        yum -y install lua-devel --enablerepo=powertools
                                fi
                        else
                        fi
                fi
        fi
In Centos 8 you have the powertools repo but in rhel the repo is codeready-builder-for-rhel-8-x86_64-rpms and the command to enable it(permanently) is:
subscription-manager repos --enable codeready-builder-for-rhel-8-x86_64-rpms
Or enable per package install
yum -y install $package --enablerepo=codeready-builder-for-rhel-8-x86_64-rpms
The validation between Centos and RHEL can be done based con the content of /etc/redhat-release or using the default name of the main repo file (like oracle linux):
/etc/yum.repos.d/redhat.repo
Centos:
# cat /etc/redhat-release
CentOS Linux release 8.1.1911 (Core)
RHEL:
Red Hat Enterprise Linux release 8.3 (Ootpa)
I dont know in how many occurrences this problem can be present, but I have the same problem with this packages:
oniguruma-devel
libnghttp2-devel
yajl-devel
If I check in the build code:
[root@dgh custombuild]# grep "enablerepo=powertools" build
                                                yum -y install oniguruma-devel --enablerepo=powertools
                                                yum -y install autoconf213 --enablerepo=powertools
                                yum -y install libnghttp2-devel --enablerepo=powertools
                                        yum -y install ${RPM_TO_INSTALL} --enablerepo=powertools
                                        yum -y install yajl-devel --enablerepo=powertools
Regards!
Fixed, thank you for the report.
A little copy error:
In line 13201 saids:
yum -y install autoconf213 --enablerepo=codeready-builder-for-rhel-8-x86_64-rpms
Must be:
yum -y install oniguruma-devel --enablerepo=codeready-builder-for-rhel-8-x86_64-rpms
In line 15386 saids
Must be:
yum -y install libnghttp2-devel --enablerepo=codeready-builder-for-rhel-8-x86_64-rpms
In line 16411 saids:
Must be:
yum -y install ${RPM_TO_INSTALL} --enablerepo=codeready-builder-for-rhel-8-x86_64-rpms
the "build" script is on a git repo? I think can be more easy check the changes using the graphical git diff.
