Cant update to Curl 7.76.1
Active8
On one of our boxes we cant install the latest curl:
vtls/openssl.c: In function 'SSL_CTX_use_certificate_chain_blob':
vtls/openssl.c:734: error: 'in' undeclared (first use in this function)
vtls/openssl.c:734: error: (Each undeclared identifier is reported only once
vtls/openssl.c:734: error: for each function it appears in.)
make[2]: *** [vtls/libcurl_la-openssl.lo] Error 1
make[2]: Leaving directory `/usr/local/directadmin/custombuild/curl-7.76.1/lib'
make[1]: *** [all] Error 2
make[1]: Leaving directory `/usr/local/directadmin/custombuild/curl-7.76.1/lib'
make: *** [all-recursive] Error 1
[root@srv1 custombuild]# curl -V
curl 7.75.0 (x86_64-pc-linux-gnu) libcurl/7.75.0 OpenSSL/1.0.1e-fips zlib/1.2.3 zstd/1.4.5 nghttp2/1.42.0
Release-Date: 2021-02-03
Protocols: dict file ftp ftps gopher gophers http https imap imaps mqtt pop3 pop3s rtsp smb smbs smtp smtps telnet tftp
Features: alt-svc AsynchDNS HTTP2 HTTPS-proxy IPv6 Largefile libz NTLM NTLM_WB SSL UnixSockets zstd
This is an Centos 6 box with Extended Lifecycle Support from Cloudlinux till 2024, but i don't think this has anything to do with it
look like need some patch fix for openssl less than 1.1
Centos 8 work fine
A quick fix is to
# untarzip the curl package
tar -zxvf curl-7.76.1.tar.gz
#change to the directory where the error occurs
cd curl-7.76.1/lib/vtls/
# edit the file and remove the unused/unreference variable "(void)in" line at line 734
sed -i '734d' ./openssl.c
# make the file immutable to prevent vustombuild from overwriting it
chattr +i openssl.c
# build curl
./build curl
# is everything is ok, remove the immutable flag from openssl.c
chattr -i openssl.c
# cleanup
rm -rf curl-7.76.1/
I had another weird issue:
in the GUI it spits out fread() errors (enhanced skin), but running it from the cli works fine. I assume some issue with custombuild.
edit: I've tried building it from the gui again and that worked fine. I assume some temporary bug or something, weird :p
I get this on Debian 8 too...... So, I guess it's upgrade OS or GTFO..... No guessing as to what I'm choosing! ;)
Well, I think this is just a bug in the patch DA made. It's not in the original curl source code.
It pity that no one from the staff replied on this thread.
There is something wrong with the CS script and thanks to you we have managed to overcome the problem with the Centos 6 box, but I have expected this would fixed by DA but they didnt, even no any reply or whatsever
You extracted original curl package, then removed line 734. Why do you think it's a patch from DA?
By the way, is any non-eol OS affected?
Thank you.
Thank you.
Because it's not in the original curl sourcecode but is in the source from the da-servers. Seemed obvious to me?
[root@development custombuild]# wget https://curl.se/download/curl-7.76.1.tar.gz
2021-05-19 20:25:40 (21.9 MB/s) - 'curl-7.76.1.tar.gz' saved [4096973/4096973]
[root@development custombuild]# md5sum curl-7.76.1.tar.gz
483abfeed7253b4791dbaa955a831dda  curl-7.76.1.tar.gz
[root@development custombuild]# rm -f curl-7.76.1.tar.gz
[root@development custombuild]# wget https://files-fr.directadmin.com/services/custombuild/curl-7.76.1.tar.gz
2021-05-19 20:26:39 (107 MB/s) - '/usr/local/directadmin/custombuild/curl-7.76.1.tar.gz' saved [4096973/4096973]
483abfeed7253b4791dbaa955a831dda = 483abfeed7253b4791dbaa955a831dda
Good to see that this thread makes progress
@smtalk Yes, this is an EOL Centos 6 but as said in the first post we have an subscription with Cloudlinux for extended support, we are getting all relevant updates and security fixes on regular base
The question here is what is the solution then if the one offered by @sysdev is not correct?
Hmm, i looked in this file: https://github.com/curl/curl/blob/master/lib/vtls/openssl.c
It's not there so i presumed it was the result of a patch. My bad!
Why wouldn't it be correct? It's basic c...
I agree that it wont hurt and your solution just works, but when I look how @smtalk react it looks like he is not happy the way you solved this
An other side, I still don't see any solutions from DA staff for this problem only reply on the fix you had provide.
An extra check in CS must look if there is an supported OS on the server or not before listing this update
I assume they are not going to fix this
Oh, I don't know about that. I presumed it was a DA patch, it wasn't. It also wasn't in the online sourcecode. But the tar.gz has a date of 14 apr. And the source file is changed only 12 days ago.
So it just looks like a bug in the current tar.gz where the (void)in is replaced with void(blob) which fixes it already. Besides waiting for a new version, DA doesn't really have to do anything.
No, I'm really happy to see @sysdev participating there :) I just want to collect more details on it, and it'd be the best to use a patched version from cURL or to always downgrade on EOL systems. We could backport the patch - but I've still got no details if CentOS 7/8, Debian 9/10, Ubuntu 18.04/20.04 or FreeBSD 11/12 are affected. I was unable to reproduce it on any non-EOL system, we've got no tickets yet, it didn't sound pretty serious/urgent to solve. And yes, I agree - it needs to be solved, I just didn't want to take any urgent actions to make things worse.
