Good day
I am having issues where I have installed the latest version of Directadmin.
I modified my named.conf.options as follows.
I then installed a new directslave server as per this script https://github.com/afrizal-id/directslave-install
And this is how the named.conf file looks like
But when I add a domain into DirectAdmin it does not update the domain to my directslave server.
Anything I am missing?
Any advice will appreciated.
options {
// allow-transfer { none; };
allow-query { any; };
allow-notify { 2.2.2.2; };
allow-transfer { 2.2.2.2; };
directory "/var/cache/bind";
// If there is a firewall between you and nameservers you want
// to talk to, you may need to fix the firewall to allow multiple
// ports to talk. See http://www.kb.cert.org/vuls/id/800113
// If your ISP provided one or more IP addresses for stable
// nameservers, you probably want to use them as forwarders.
// Uncomment the following block, and insert the addresses replacing
// the all-0's placeholder.
// forwarders {
// 0.0.0.0;
// If BIND logs error messages about the root key being expired,
// you will need to update your keys. See https://www.isc.org/bind-keys
dnssec-validation auto;
listen-on-v6 { any; };
options {
listen-on port 53 { any; };
listen-on-v6 port 53 { none; };
directory "/var/named";
dump-file "/var/named/data/cache_dump.db";
statistics-file "/var/named/data/named_stats.txt";
memstatistics-file "/var/named/data/named_mem_stats.txt";
recursing-file "/var/named/data/named.recursing";
secroots-file "/var/named/data/named.secroots";
allow-notify { 1.1.1.1; };
allow-transfer { 1.1.1.1; };
