Error while backup MySQL
mbsmt
Mashhad, Iran
I have a daily backup procedure on DA. It's 3 days that I have an error only for one user.
As this error happens only on just one user, I could not resolve the issue by the given repair guide link.
May you help me to solve this issue please?
What did you change?
I never had any /usr/local/directadmin/conf/my.cnf.username file, only my.cnf and mysql.conf both created by DA during installation.
Also I wonder why user "nobody" would need to create a backup.
Are you running mod_php without mod_ruid2 or someting?
Looks to me there are some customisations made which mess things up.
Richard, I am using PHP-FPM. However, as you said I knew that one of my teammates did something to check conditions on this account on the server and forgot to remove them. This is why I faced with such problem which I have not experienced up to now.
So sorry for my mistake to post this thread.
It's never a mistake to post a thread of you have a problem with something. No matter what caused it. So no need to say sorry either.
But it's hard to create a solution if it's not known if and what might be changed if things look different as they look in a default setup. That's why I asked if custom changes were made. ;)
Is your issue solved now or are your still experiencing poblems?
It is solved now. Thanks for asking ... ;)
