Solved DA 1.62 RC2 Problem with realtime console output
Ohm J
Browser: Opera
Centos 8 with CgroupV2 enable
when start build,.... eg. builld php
it's not show output what's going on until success building
eg. it show only
Opening log..
in now, for quick fix
just add ' echo "Content-Encoding: none\n"; ' to "/build_software_command.raw" and "/show_log.raw"
echo "HTTP/1.1 200 OK\n";
echo "Content-Type: text/html\n\n";
other page I don't test it, I just test only Build Software Page
anyelse suggestion ?
UPDATE 2021 June 05
echo "Content-Type: text/event-stream\n\n";
"Content-Type: text/event-stream" with "Content-Encoding: none" better than"text/html"
but work in some newest browser
because browser need some data 1024bytes before display
Even on "/CMD_ADMIN_BACKUP?action=monitor&pid=XXXXX" got same problem, I thing all page that use realtime output have all affectly
May you check if latest pre-release solves it? (it should) Thank you for the report!
it working now
Compiled onCentOS 8.0 64-Bit
Compile DateJun 8 2021, 13:58:07
Server Version1.61.5
Current Available Version1.615000
Last UpdatedWed Jun 9 02:59:07 2021
Last RestartWed Jun 9 06:55:19 2021
