Host localhost not found: 3(NXDOMAIN)
castris
Arcenillas
Hi.
I have inherited a system with Directadmin and ubuntu 20.04
When going to install wiki.js I ran into a MySQL accessibility problem.
The reason is that the software does not detect or validate the configuration for accessing the database.
After verifying in the shell that the data was correct, note that the user cannot access via localhost in said software, but in the shell he can.
When checking, I saw a localhost resolution problem
Bash:
# host localhost
Checking the /etc/hosts file​
Bash:
# Do not remove the following line, or various programs
# that require network functionality will fail.
127.0.0.1 localhost localhost.localdomain
127.0.1.1 server-myhost
::1     ip6-localhost   ip6-loopback
fe00::0 ip6-localnet
ff00::0 ip6-mcastprefix
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
ff02::3 ip6-allhosts
Checking /etc/nsswitch.conf​
hosts:          files dns
networks:       files
Any ideas?
Is there a real IP address for the server?
its should be like
123.456.789.12 servername.domain.com servername
also what is in the /etc/my.cnf
is skip-name-resolve on?
Of course no.
127.0.1.1 is a private net.
Full file (of course public ip is fake)
Of course no.
To what question?
I am not asking for your IP address. I am trying determine is the server on the internet? OR are you saying its a LAN based install?
127 is a loopback notation and is confusing if you are trying not to show a real IP or not I would use some other notation. like ###.###.###.###
Ok.
Sorry for my english.
1. Server is a server on Internet. Not local.
2. Configuration of hosts is correct for one server on internet
Question is on post.
If running a command host with parameters localhost get error.
host localhost
Correct execution must return
# host localhost
localhost has address 127.0.0.1
localhost has IPv6 address ::1
With this fail thre're some servidor (daemons) that can get error.
For server if run
# host myhost.server.com
myhost.server.com has address 1.1.8.8 # Of course is fake number ip
Is information correct? Any more for you?
My Spanish would be worse no problem. Let me add beautiful country..
Also @SeLLeRoNe here on Forum is a native to your country. He is a very good Admin
So if you go here
https://intodns.com/
put in your domain
do any errors jump out at you?
Hi
- domain has not any problem with resolution.
- hostname resolve ok inside and outside of server.
- Not issues with domain resolution on any domain or subdomain on server.
Issue is WITH internal question about localhost
nslookup, dig, intodns and any probe work fine for resolver domain and FDQN hostname.
UNIQUE problem is
host localhost
Apreciate help of @SeLLeRoNe
Since everything else is resolving fine as you say..... What if you put this in the correct order and restart your network (or better, restart the server)?
Correct order should be:
127.0.0.1 localhost.localdomain localhost
