BUG: jail=2
factor
USA
From my system. Never set this as its not in my process.
da c | grep jail
jail=2
Something updated the default from 0
Must be this
    #enable jail=2 server-wide
    if [ -s ${DACONF_FILE} ]; then
        if ! grep -q -m1 'jail=0' ${DACONF_FILE}; then
            setVal jail 2 ${DACONF_TEMPLATE_FILE}
            setVal jail 2 ${DACONF_FILE}
            doRestartDA
        fi
    fi
the template is changed
cat directadmin.conf
#DirectAdmin config file
#For full listing of set variables, run: /usr/local/directadmin/directadmin c
#For information on a given variable, search it in the versions system: https://directadmin.com/versions.php
#More information on setting values to the directadmin.conf: https://help.directadmin.com/item.php?id=641
nginx_proxy=0
litespeed=0
openlitespeed=0
frontpage_on=0
apache_ver=2.0
jail=2
pureftp=0
from https://docs.directadmin.com/directadmin/general-usage/all-directadmin-conf-values#jail
jail​
jail=0
Use bubblewrap to jail users (cronjobs, shell and PHP-FastCGI). Use CustomBuild to install bubblewrap, it sets the DirectAdmin value automatically.
ValueComment
0jail disabled completely
1jail is enabled by default, but can be personally disabled per package, reseller.conf or user.conf
2jail is enabled forcefully for all
Please check it to making a correction to the system. So we can avoid this issue from happening.
@smtalk @DirectAdmin Support
Sorry I put it here it needs to be in CB2 I suppose.
Thank you for the report, it should have been set to 1. Fixed!
@smtalk are there any steps if i actualy want to enable this? (Apart from installing bwrap and jailshell). And does it have any caveats? (i read something with exim a while back)
Exim should work just fine. There should be a “Jail” checkbox when modifying user or user package.
Now all you need to do is add a remove routine for brwrap, jailshell and redis
