DirectAdmin 1.62.1 has been released
DirectAdmin Support
Administrator
Staff member
Hello!
DirectAdmin 1.62.1 has been released.
This is mainly a bug-fix release to follow the very large 1.62.0 release, one week ago.
All changes can be found here:
Features/Changes:
Bug-fixes:
Update:
  • To get this release, go to:
    Admin Level » Licenses/Updates » Update Directadmin
    and let us know if there are any issues.
I'm using your.hostname.com, SSL=1
$config['password_directadmin_host'] = 'ssl://localhost';
$config['password_directadmin_port'] = 1234;
Users change email password from Roundcube ->OK.
But after update version 1.62 and upgrade version 1.62.1. Users can't change their email password from Roundcube.
How can i fix it ?
Missing the following option in SSL-Certicates, to add CA Root certifcate in the new SKIN.
HMMM!
Update gives:
CENTOS 8 lanip config while openstack instance,
CustomBuild
2.0.0 (rev: 2722)
As Admin revo skin
  • Executing /usr/local/directadmin/plugins/custombuild/admin/build update_da...
  • [1mUpdating DirectAdmin(B[m
2021:06:17-13:53:30: pid 2574845 killed by signal 15 (data: {"data":"\u001b[1mUpdating DirectAdmin\u001b(B\u001b[m\n","finished":false}
he
data: {"data":"","pid":"2574848","finished":false}
2021:06:17-13:55:02: pid 2575035 killed by signal 15 (data: {"data":"\u001b[1mUpdating DirectAdmin\u001b(B\u001b[m\n","finished":false}
he
data: {"data":"","pid":"2575038","finished":false}
2021:06:17-13:55:02: [error] proxy request error error=context canceled url=http://unix/CMD_AJAX_GET_COUNTS?json=yes&all=yes
2021:06:17-13:55:02: [error] proxy request error error=context canceled url=http://unix/JS_HELPER_LINKS?json=yes
2021:06:17-13:55:02: [error] proxy request error error=context canceled url=http://unix/CMD_JSON_LANG?json=yes&lang=user
2021:06:17-13:55:02: Socket write error: fd is connected to a pipe or socket whose reading end is closed. When this happens the writing process will also receive a SIG_PIPE signal. (Thus, the write return value is seen only if the program catches, blocks or ignores this signal.)
2021:06:17-13:55:02: Send:sendData(/JS_HELPER_LINKS): attempted to send 8766 bytes, but only 0 were delivered
2021:06:17-14:03:55: pid 2615771 killed by signal 15 ()
2021:06:17-14:03:55: Tally::get_user_quota: admin: error with get_mount_points for realtime_quota=2
But version is not showing after this update in custombuild update anymore.
Compiled onCentOS 8.0 64-Bit
Compile DateJun 16 2021, 16:24:41
Server Version1.62.1
Current Available Version1.62.1000
Last UpdatedThu Jun 17 13:55:02 2021
Last RestartThu Jun 17 13:56:01 2021
After try again the imagemagick update gives done! but actualy still running and not ready at all. see image 4
Closing at the end with errors:
  • CC filters/MagickCore_libMagickCore_7_Q16HDRI_la-analyze.lo
  • CCLD MagickCore/libMagickCore-7.Q16HDRI.la
  • gcc: error: libMagickCore-7.Q16HDRI.so.10: No such file or directory
  • gcc: error: unrecognized command line option '-soname'
  • make[1]: *** [Makefile:7082: MagickCore/libMagickCore-7.Q16HDRI.la] Error 1
  • make[1]: Leaving directory '/usr/local/directadmin/custombuild/ImageMagick-7.1.0-0'
  • make: *** [Makefile:6121: all] Error 2
Did this before so files.direct..
  • r/local/directadmin/plugins/custombuild/admin/build update_script...
  • --2021-06-17 -- https://files.directadmin.com/services/custombuild/2.0/custombuild.tar.gz
  • Resolving files.directadmin.com (files.directadmin.com)... 185.42.221.168, 69.162.69.58, 104.128.54.74
  • Connecting to files.directadmin.com (files.directadmin.com)|185.42.221.168|:443... connected.
  • HTTP request sent, awaiting response... 200 OK
  • Length: 263024 (257K) [application/x-gzip]
  • Saving to: './custombuild.tar.gz'
  • 0K .......... .......... .......... .......... .......... 19% 501K 0s
  • 50K .......... .......... .......... .......... .......... 38% 1.10M 0s
  • 100K .......... .......... .......... .......... .......... 58% 790K 0s
  • 150K .......... .......... .......... .......... .......... 77% 714K 0s
  • 200K .......... .......... .......... .......... .......... 97% 712K 0s
  • 250K ...... 100% 149M=0.3s
  • Resolving files.directadmin.com (files.directadmin.com)... 69.162.69.58, 185.42.221.168, 104.128.54.74
  • Connecting to files.directadmin.com (files.directadmin.com)|69.162.69.58|:443... connected
Just looked and see nothing. maybe i miss a thing
I don't see URLs on the right side in your 2nd screenshot, may you screenshot that part as well? As this is the place where "SSL CA Certificate" URL should be shown.
You mean this?
It should be available in “paste” tab only. I may login to your system to check it if you’re out of ideas :)
You are right is was the cache in the system that fails :) :)
