New Automatic SSL doesn't work for pointers
k1l0b1t
Belgium
Situation:
domain1.com has a pointer domain2.com
SSL gets created for both, but domain2.com shows SSL of domain1.com.
Checked the VHOST file, and there the vhost for domain2.com uses the certificate for domain1.com
Directadmin does pick up the certificate though, so it actualy exists and is valid.
Also: when deleting the pointer, the cerftificate file isn't deleted, just not shown anymore in the list on the SSL screen (directadmin can still use the certificate). Looks like directadmin caches it, but does not unload the certificate when it's deleted.
It’s a known issue fixed in pre-release.
Regarding removal of the certs: it’ll be checked, thanks!
Hello!
I've just checked the code and tested (using latest binaries), and when deleting a pointer, the matching cert data, eg:
/usr/local/directadmin/data/users/fred/domains/pointer.com.*
does get deleted along with it.
This code was added on April 15th, so should... be in the full 1.62.0 and up.
Let me know if the pointer.com.cert file is what you're referring to.. and if not, let me know.
So far, 1.62.3 has the following documented changes:
From what i tested yesterday, the cert file on disk did get deleted, but directadmin kept serving the cert on :2222, which should not be the case (unless it got cached by DA, and would get unloaded eventualy after while)
