Erik66
I have used this article https://help.directadmin.com/item.php?id=629 to setup my server with a LE SSL certificate for all services. Yet, I can not connect to dovecot, neither via imap nor pop3, using a connection on any port that should use SSL. I use standard ports for dovecot and exim. The LE certificates are stored in /usr/local/directadmin/data/users/<USERNAME>/domains/<USERNAME>.cert ... etc. I even copied the contents of the .cert and .key files to /etc/exim.cert and /etc/exim.key . In the direactadmin.conf file, the parameters cacert and cakey point to the above files. carootcert points to /usr/local/directadmin/conf/bundle.crt.
Using SSLlabs checker I find the certificate at my server is actually A graded. But I assume this is because it checks port 443 and none of the ports used for email are checked here.
Does anybody have a suggestion where I could start looking for a solution?
Many thanks in advance,
Erik
Erik
