Resource Limits won't work
m_mousavi
Hello everyone,
As you already know in new directadmin release, we have the resource limits feature that we can limit resources per user without using cloud Linux.
I set 200% for cpu quota for specific user . but I see this limitation doesnt work well . you can see in the attachment , that this user pass his cpu quota and directadmin didn't limit this user.
thanks in advance for your help
Are you sure it wasn't a temporary spike? I'd suggest opening a ticket if you're sure it doesn't get limited (it should be limited though).
yes , I'm sure .
actually I did a load test to the specific site on the server (JMeter - Only get request) . I expected to only use 2 cores but I see nearly all my server's cores are busy .
I continued test for five minutes but still use all my cores.
yes , I'm sure .
Was php recompiled after? What’s your php mode?
