scoreboard is full, not at MaxRequestWorkers.Increase ServerLimit
qba82
Hi, after about month of working my apache is not serving any website, even if it is running just fine, until apache is restarted (then everything work just fine), it happens like 3 times now since last months.
In error log I found this:
[Tue Jul 13 10:37:54.440017 2021] [mpm_event:error] [pid 1638:tid 139662962415744] AH03490: scoreboard is full, not at MaxRequestWorkers.Increase ServerLimit.
My current MPM settings is:
Server MPM: event
nano /etc/httpd/conf/extra/httpd-mpm.conf
<IfModule mpm_event_module>
StartServers 6
MinSpareThreads 32
MaxSpareThreads 128
ThreadsPerChild 64
ServerLimit 32
MaxRequestWorkers 2048
MaxConnectionsPerChild 10000
</IfModule>
I have 256GB RAM, how can I fix it?
maybe you need to custom that file
change value
ServerLimit 40
MaxRequestWorkers 2560
note:
MaxRequestWorkers = ThreadsPerChild * ServerLimit < Available Memory ( Ram)
this problem will happend when you have too much client connection to your website
i have the same problem,
StartServers 6
MinSpareThreads 32
MaxSpareThreads 128
ThreadsPerChild 64
ServerLimit 32
</IfModule>
i have changed settings
ServerLimit 40
but after ./build rewrite_confs in DirectAdmin, the settings return to the original.
Hi, I have to get back to this problem because it is not solved.
I still get this error:
I have increased settings to:
StartServers 6
MinSpareThreads 32
MaxSpareThreads 128
ThreadsPerChild 64
ServerLimit 128
MaxRequestWorkers 8192
</IfModule>
but still after few days apache not loading any websites, I noticed that after I restart apache and when I check its status, by "service httpd status" I can see correct PIDs, for example:
├─14627 /usr/local/php74/bin/php-cgi74 -d sendmail_path=/usr/sbin/sendmail -t -i -f [email protected] -d sendmail_from="[email protected]" -d open_basedir="...
├─14628 /usr/local/php74/bin/php-cgi74 -d sendmail_path=/usr/sbin/sendmail -t -i -f [email protected] -d sendmail_from="[email protected]...
├─14629 /usr/local/php74/bin/php-cgi74 -d sendmail_path=/usr/sbin/sendmail -t -i -f [email protected] -d sendmail_from="[email protected]...
├─14630 /usr/local/php74/bin/php-cgi74 -d sendmail_path=/usr/sbin/sendmail -t -i -f [email protected] -d sendmail_from="[email protected]" -d open_b...
but when apache is stuck, on its status it showing ONLY below PIDs:
├─14072 /usr/sbin/httpd -DFOREGROUND
├─14073 /usr/sbin/httpd -DFOREGROUND
├─14075 /usr/sbin/httpd -DFOREGROUND
├─14095 /usr/sbin/httpd -DFOREGROUND
├─14154 /usr/sbin/httpd -DFOREGROUND
any idea how to fix it?
you must check which processes stuck, a lot of sendmail - someone spamming?
change value
ServerLimit 40
note:
Thank you very much for the answer. In which file needs to make the changes?
