E exemaco Verified User Joined Dec 14, 2019 Messages 37 Jul 16, 2021 #1 Hi, When generating a backup from the control panel it does not finish completing, the problem is only with this user, the other accounts work correctly. the account only weighs 400M, they have an idea what it could be? Thanks! Last edited: Jul 28, 2021
factor Verified User Joined Jul 22, 2017 Messages 3,473 Location USA Jul 17, 2021 #2 Did you check how much free space is left on the account? Depending on the free space setting it could be stop in the backup.
E exemaco Verified User Joined Dec 14, 2019 Messages 37 Jul 20, 2021 #3 bdacus01 said: Did you check how much free space is left on the account? Depending on the free space setting it could be stop in the backup. Click to expand... Hello, the account has 4gb allocated, so it shouldn't be a space problem.
O Ohm J Verified User Joined Aug 16, 2019 Messages 2,196 Jul 20, 2021 #4 try debug 1: Create Backup from Admin Backup 2: go to ssh console-> run Code: /usr/local/directadmin/dataskq d2000 > /root/debug_dataskqoutput.txt you need fast input coomand after create backup otherwise, task will handle by crontab if you want more debug info use "d5000" then read debug info from "/root/debug_dataskqoutput.txt"
