point a domain to a path
ai8
A domain needs to be directed to a path, e.g.
domain1.com
to serve files from
domain1.com/mypaths/path4domain1
as the base path (i.e. show only domain1.com in the URL address field of the browser).
Once one goes deeper into e.g.
domain1.com/mypaths/path4domain1/subdir
it would show domain1.com/subdir in the URL address bar.
How can above redirection/designation be done using DA?
Many thanks!
I don't understand the problem. Normally this is the default setup, files will be served from:
/home/user/domains/domain1.com/public_html
when the domain is visited, in the URL address only domain1.com is visible, so that is already like you ask.
It will be shown in the browser URL bar as https://domain1.com
Now if you create a subdir in that folder so it will become:
/home/user/domains/domain1.com/public_html/subdir
then in the browser it will show in the URL address bar of the browser as https://domain1.com/subdir which is also what you want.
This is the default, so it normally always works like this. So I don't really understand the issue you're having.
Thinking this is possibly what you want:
I do this for some customers that run some frameworks that place the actual web root a level or two down.
Otherwise it would be possible to construct an .htaccess file, to basically do the same thing. It's just more tricky.
Yup could help, to have it only for one subdomain https://help.directadmin.com/item.php?id=199
Nwer knowledge base you can search more easy there https://docs.directadmin.com/webser...odify-the-open-basedir-setting-for-one-domain
Should be in GUI now : "For DirectAdmin versions prior to Version 1.61.0 (before the GUI was added),"
How can this be done in DA?
As described, this will be done automatically when creating a subdir.
However, it will be both reachable via subdir.domain.com and domain.com/subdir for visitors. If that is not what you want, then the solutions given by cjd and ikkeben should fix that for you.
Thank you for the above everyone!
Still after a solution.
It needs to be doable for the user (not reseller or admin/root) via GUI and work for both (sub- and) domains.
Hoping it will be implemented soon.
