SYSLOG_CHECK in CSF (60-3600), recommended number is? is there any bad effect? if i enable this.
mastoro
SYSLOG_CHECK in CSF (60-3600), what is the recommended number?
"Many of the lfd checks require syslog to be
running correctly"
so this function will check syslog working or not and notify you if not working
besure you set correct Email Receipts to get notify
Recommend value should be 600 - 3600,
too short will make your I/O loading hight
too long, can make accident when syslog is not working correctly
running correctly"
600 - 3600 = its in ms (milliseconds) ?
