Suhosin need some update changes for newer PHP versions i think see here
ikkeben
Netherlands Germany
@DirectAdmin Support
Suhosin need some overhole work?
See
The DOCS:
To check more such tools in Custombuild could be handy ( sme is in csf check but take a look
PFF found it thanks
After activating this in the Custombuild GUI and builld do you have to rebuild PHP to become active?
No, it's enough to just build the extension. Of course re-compilation of PHP would install this as well, but it's a longer process :)
