Buble wrap keep asking update custombuild evo
ikkeben
Netherlands Germany
  • Executing /usr/local/directadmin/plugins/custombuild/admin/build Bubblewrap...
  • | DirectAdmin WebServices Installer |
  • | Written by Martynas Bendorius and DirectAdmin |
  • | Version: 2.0.0 (rev: 2733) |
  • | To build everything run: |
  • | /usr/local/directadmin/custombuild/build all |
  • | [1mNOTE(B[m: Command all will compile everything as it is set |
  • | in the options.conf file, please take a look at |
  • | "/usr/local/directadmin/custombuild/build options"! |
  • | Install/update server components: |
  • | /usr/local/directadmin/custombuild/build apache |
  • | /usr/local/directadmin/custombuild/build awstats |
  • | /usr/local/directadmin/custombuild/build awstats_process |
  • | /usr/local/directadmin/custombuild/build bubblewrap |
  • | /usr/local/directadmin/custombuild/build clamav |
  • | /usr/local/directadmin/custombuild/build composer |
  • | /usr/local/directadmin/custombuild/build curl |
  • | /usr/local/directadmin/custombuild/build cpanel_to_da |
  • | /usr/local/directadmin/custombuild/build dovecot |
  • | /usr/local/directadmin/custombuild/build exim |
  • | /usr/local/directadmin/custombuild/build freetype |
  • | /usr/local/directadmin/custombuild/build geoipupdate |
  • | /usr/local/directadmin/custombuild/build icu |
  • | /usr/local/directadmin/custombuild/build imagemagick |
  • | /usr/local/directadmin/custombuild/build jailshell |
  • | /usr/local/directadmin/custombuild/build lego |
  • | /usr/local/directadmin/custombuild/build libmaxminddb |
  • | /usr/local/directadmin/custombuild/build libmodsecurity |
  • | /usr/local/directadmin/custombuild/build libspf2 |
  • | /usr/local/directadmin/custombuild/build libsrs_alt |
  • | /usr/local/directadmin/custombuild/build libsodium |
  • | /usr/local/directadmin/custombuild/build libxml2 |
  • | /usr/local/directadmin/custombuild/build libxslt |
  • | /usr/local/directadmin/custombuild/build litespeed |
  • | /usr/local/directadmin/custombuild/build lua |
  • | /usr/local/directadmin/custombuild/build mod_lsapi |
  • | /usr/local/directadmin/custombuild/build mod_proctitle |
  • | /usr/local/directadmin/custombuild/build mod_aclr2 |
  • | /usr/local/directadmin/custombuild/build mod_ruid2 |
  • | /usr/local/directadmin/custombuild/build mod_htscanner2 |
  • | /usr/local/directadmin/custombuild/build mod_fcgid |
  • | /usr/local/directadmin/custombuild/build modsecurity |
  • | /usr/local/directadmin/custombuild/build modsecurity_rules |
  • | /usr/local/directadmin/custombuild/build msmtp |
  • | /usr/local/directadmin/custombuild/build mysql |
  • | /usr/local/directadmin/custombuild/build netdata |
  • | /usr/local/directadmin/custombuild/build nginx |
  • | /usr/local/directadmin/custombuild/build nginx_apache |
  • | /usr/local/directadmin/custombuild/build openlitespeed |
  • | /usr/local/directadmin/custombuild/build pigeonhole |
  • | /usr/local/directadmin/custombuild/build pigz |
  • | /usr/local/directadmin/custombuild/build pcre |
  • | /usr/local/directadmin/custombuild/build php |
  • | /usr/local/directadmin/custombuild/build proftpd |
  • | /usr/local/directadmin/custombuild/build pureftpd |
  • | /usr/local/directadmin/custombuild/build redis |
  • | /usr/local/directadmin/custombuild/build rspamd |
  • | /usr/local/directadmin/custombuild/build snail |
  • | /usr/local/directadmin/custombuild/build spamassassin |
  • | /usr/local/directadmin/custombuild/build suphp |
  • | /usr/local/directadmin/custombuild/build unit |
  • | /usr/local/directadmin/custombuild/build webalizer |
  • | Install/update PHP extensions: |
  • | /usr/local/directadmin/custombuild/build php_gmp |
  • | /usr/local/directadmin/custombuild/build php_ioncube |
  • | /usr/local/directadmin/custombuild/build php_imagick |
  • | /usr/local/directadmin/custombuild/build php_imap |
  • | /usr/local/directadmin/custombuild/build php_ldap |
  • | /usr/local/directadmin/custombuild/build php_opcache |
  • | /usr/local/directadmin/custombuild/build php_phalcon |
  • | /usr/local/directadmin/custombuild/build php_psr |
  • | /usr/local/directadmin/custombuild/build php_redis |
  • | /usr/local/directadmin/custombuild/build php_readline |
  • | /usr/local/directadmin/custombuild/build php_snuffleupagus |
  • | /usr/local/directadmin/custombuild/build php_suhosin |
  • | /usr/local/directadmin/custombuild/build php_xmlrpc |
  • | /usr/local/directadmin/custombuild/build php_zend |
  • | Components configuration options: |
  • | /usr/local/directadmin/custombuild/build exim_conf |
  • | /usr/local/directadmin/custombuild/build dovecot_conf |
  • | /usr/local/directadmin/custombuild/build blockcracking |
  • | /usr/local/directadmin/custombuild/build easy_spam_fighter |
  • | /usr/local/directadmin/custombuild/build php_ini |
  • | /usr/local/directadmin/custombuild/build rewrite_confs |
  • | /usr/local/directadmin/custombuild/build secure_php |
  • | /usr/local/directadmin/custombuild/build spamassassin_cron |
  • | /usr/local/directadmin/custombuild/build litespeed_license |
  • | /usr/local/directadmin/custombuild/build litespeed_license_migrate |
  • | Install/update web applications: |
  • | /usr/local/directadmin/custombuild/build phpmyadmin |
  • | /usr/local/directadmin/custombuild/build roundcube |
  • | /usr/local/directadmin/custombuild/build squirrelmail |
  • | CustomBuild related options/functions: |
  • | /usr/local/directadmin/custombuild/build create_options |
  • | /usr/local/directadmin/custombuild/build custombuild_plugin |
  • | /usr/local/directadmin/custombuild/build cron |
  • | /usr/local/directadmin/custombuild/build opt_help |
  • | /usr/local/directadmin/custombuild/build options |
  • | /usr/local/directadmin/custombuild/build list_removals |
  • | /usr/local/directadmin/custombuild/build remove_items |
  • | /usr/local/directadmin/custombuild/build set |
  • | /usr/local/directadmin/custombuild/build set_fastest |
  • | /usr/local/directadmin/custombuild/build set_fastest_quiet |
  • | /usr/local/directadmin/custombuild/build update_da |
  • | /usr/local/directadmin/custombuild/build update_versions |
  • | /usr/local/directadmin/custombuild/build update_webapps |
  • | /usr/local/directadmin/custombuild/build used_configs |
  • | /usr/local/directadmin/custombuild/build versions |
  • | /usr/local/directadmin/custombuild/build version |
  • | Remove old build data: |
  • | /usr/local/directadmin/custombuild/build clean |
  • | /usr/local/directadmin/custombuild/build clean_old_webapps |
  • | Get latest build script with or without new packages: |
  • | /usr/local/directadmin/custombuild/build update |
  • | /usr/local/directadmin/custombuild/build update_script |
  • | Get packages for current build script: |
  • | /usr/local/directadmin/custombuild/build update_data |
  • | Build everything what is set in the options.conf file: |
  • | Build all PHP extensions set set in the php_extensions.conf file: |
  • | /usr/local/directadmin/custombuild/build php_extensions |
  • | Recommended for experienced users only (!): |
  • | /usr/local/directadmin/custombuild/build php_expert php_release php_mode |
  • | /usr/local/directadmin/custombuild/build php_htscanner2 php_release |
  • | /usr/local/directadmin/custombuild/build todovecot |
  • | /usr/local/directadmin/custombuild/build set_service service ON|OFF|delete |
  • | You can pass a 2nd argument to automate the input: |
  • | /usr/local/directadmin/custombuild/build <option> d : do the default action |
  • | /usr/local/directadmin/custombuild/build <option> y : answer yes to all questions |
  • | /usr/local/directadmin/custombuild/build <option> n : answer no to all questions |
So that is log file update 0.40 to 0.41 but it is keeping there is update ...
Edge windows 10 pro
Same problem here @DirectAdmin Support @smtalk .
We are using CloudLinux 8 and have never installed Bubblewrap or Jailshell manually. We also don't use the "jail" option in directadmin.conf
Some Custombuild builds ago started to show:
Bubblewrap 0.4.0 to 0.4.1 update is available.
But when we try to update:
$ ./build bubblewrap
Please rely on CloudLinux CageFS for isolation of the users (cloudlinux=yes detected in the settings).
Apparently Custombuild or Directadmin improperly installed Bubblewap at some point, despite CloudLinux OS, but there are no options for disabling, nor instructions for removing it.
I guess it might have been installed at the time the box wasn't converted to CloudLinux. The following should solve it:
rm -f /usr/bin/bwrap
rm -f /usr/bin/jailshell
Thanks for the info Martynas, it solved the problem.
This box has not been converted, it is a fresh install from the CloudLinux ISO 8.2, so maybe you might want to check out the Custombuild for a possible bug, as Bubblewrap was automatically and improperly installed.
Here same kind of problem i think, here none cloudlinux , keeps asking for update avaiable.
But i mentioned this more times before month or so ago see topic above
centos8 alma
I got this installed with fresh directadmin installation (so it is installed by default):
make[2]: Leaving directory '/usr/local/directadmin/custombuild/bubblewrap-0.4.1'
 /usr/bin/mkdir -p '/usr/share/bash-completion/completions'
 /usr/bin/install -c -m 644 completions/bash/bwrap '/usr/share/bash-completion/completions'
make[1]: Leaving directory '/usr/local/directadmin/custombuild/bubblewrap-0.4.1'
Are you sure you have cloudlinux=yes in the options.conf file?
