How do you insert MX record without subdomain?
MaXi32
The Earth
I have this requirement to add an MX record without subdomain using the GUI below:
So I leave the field (after value 10 as a blank field to represent it does not have a subdomain) but, when I try to add the above record, it showed me this error:
Cannot Add Record​
You must provide a valid name and value
Is there a special symbol that can represent this blank field? Tried the dot symbol it works. But is it a valid representation of an MX record without a subdomain?
So you want to use domain.com instead of mail.domain.com correct?
Try this. After Value 10, put in this:
domain.com.
mind the trailing dot. Should work this way.
