Don't understand this help doc is it old or still ok? limit of 10 internal redirects
ikkeben
Netherlands Germany
@scriptkitty
"php-FPM: the Request exceeded the limit of 10 internal redirects due to probable configuration error"
But help i saying this so how where to change or find new help ???
DA 1.43.0 and newer will use the mod_proxy_fcgid (apache built-in module) instead of mod_fastcgi, so this guide will no longer apply.
Exceeding the redirect can be caused by for example too many redirects to 403 page, or little mistake in .htaccess file.
I found this, maybe it can help you to check it out.
Also, different thread, but same error notice, maybe this can help you too.
Yes but only few errors sometimes bingbot mostly from scammers trying to do .....
Therefore that solution should work but is to old for the used fpm now and latest DA, also if you want to extend that limit a bit i can't find a DA solution.
It is not for the hostname at our box as in that topic. ( and no alias)
But thanks ofcourse
Could be a old popup content link, that is not handled the same in newer system after migration while can't find the url, and maybe then a kind of redirect not working don't know fews times a day now only bingbot and sometimes for scammers trying to reach the known security problems wp for example.
NON WP on server! ;)
