sufiyanshaikh
- Aug 14, 2019
but anyway Apache 2.4.48 with nginx-1.21.3 worked before .. with apache .49 update also ...
Upgrade to Apache 2.4.49 and check if it solves your issue
Not on my servers. So I won't downgrade.have you been able to reproduce any issue ?
is there a way to force .49 version as normal rebuilds install .48 only ?Upgrade to Apache 2.4.49 and check if it solves your issue
well
I was surprised to see that custombuild is back to 2.4.48, so I'll be monitoring this thread and hopefully we'll see an update soon.
Edit: have now updated around 80 other (non-DirectAdmin) boxes with 2.4.49 with no negative consequences, so I'm surprised that it doesn't work on DA...
I don't think that it something has to do with DA, its likely more an combination of thing/plugins/extensionsso I'm surprised that it doesn't work on DA...
nope, it's only Apache on my end.And it seems to be nginx_apache rather than apache on its own.
cd httpd-2.4.50/
./buildconf
Server version: Apache/2.4.50 (Unix)
Server built: Oct 5 2021 11:34:54
Server's Module Magic Number: 20120211:117
Server loaded: APR 1.7.0, APR-UTIL 1.6.1
Compiled using: APR 1.7.0, APR-UTIL 1.6.1
Architecture: 64-bit
Updated, thanks.@smtalk
2.4.50 has been release, Please add file to custombuild
I want to try update to check it solve problem hang from 2.4.49
p.s. I try download by manual and build
It's error because need to generate config file with
repack tar and rebuild againCode:cd httpd-2.4.50/ ./buildconf
in now I have
I will give it a try now.2.4.50 fix hang issued for me
