login keys
urgido
Hi
Why login keys only can be accesible if the admin or reseller has a domain? I don't need a domain under admin's account but I need a login key to my crm.
Best regards
[SOLVED]
Adding the IP through firewall was my solution. BUt I am aware of why login keys are not accessible (I mean, view details), I am redirected to "domain setup" section.
Another thing is that I am trying to debug directadmin for my PHP script but I have no luck. Any api logs are not displayed. There are no no CMD* instances wo help me on why I can't use login keys/api.
Do I missing something?
Hi
Best regards
What user does the CRM run as? Are you able to add login keys as that user?
I am using my own CRM development on CI 3.
steps to reproduce:
1.- Login as admin
2.- Create a login key
3.- Then, tried to view/edit that login key. You would experimenting a redirection to "domain setup" page.
