I tried reinstalling multiple times. I created a ticket on the topic.It seems that wget is broken for some reason there, I'd suggest to try reinstalling it. If that does not help - try opening a ticket over personal license, and assistance would be provided there.
As I mentioned above, I tried many times and it didn't work.He means reinstall wget
can you check it here?The wget binarie is from the OS and has nothing to do with Directadmin.
I also see segmentation fault. However, maybe it's wise to either translate the error notices or reinstall the OS in English default so most of us can understand the error notices and then maybe see what's going on.
It could just as well be some memory or hardware issue. Hard to see.
I don't use Litespeed so no experience with that, but I do understand this notice.php1 mode must be set to lsphp when using litespeed WEB server
./build set webserver openlitespeed
./build set php1_mode lsphp
./build set php1_release 7.4
./build openlitespeed
./build php n
./build rewrite_confs
#PHP Settings
php1_release=7.4
php1_mode=lsphp
php2_release=8.0
php2_mode=lsphp
php3_release=no
php3_mode=php-fpm
php4_release=no
php4_mode=php-fpm
