Problem sending emails via smtp
Marks
PHPMailer has the following error when trying to send email via the hosting account:
SMTP connect() failed
But when sending by the same script through my localhost WAMP server, it sends normally.
Through exim maillog I have the following errors:
2021-10-05 19:19:03 TLS error on connection from XXXX.XXX.X (WEBSITE.COM) [IP.IP.IP.IP.] (SSL_accept): NULL (TLSv1)
and also
SSL_accept (TLSv1)): error:14209102:SSL routines:tls_early_post_process_client_hello:unsupported protocol
host: mail.domain.com
port: 587
authentication: tls
email account username and password
its csf related, set an exception for the corresponding user and it works
TLSv1 is obsolete(as sslv3), you need to use TLSv1.2 or TLSv1.3, you need to update your email client.
But I don't understand, why the local upload works and the server is not working, it displays the error.
ssl configuration is OLD in custombuild
You can try this:
in: (you can create the file if isnt exist)
/etc/exim.variables.conf.custom
add:
openssl_options=+no_sslv2 +no_sslv3
tls_require_ciphers=ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-SHA256:AES128-SHA:AES256-SHA:DES-CBC3-SHA:!DSS
After that, rebuild the exim config
/usr/local/directadmin/custombuild/build exim_conf
You can try this:
add:
did not work.
see the phpmailer return on the server
2021-10-06 12:10:39 SERVER -> CLIENT: 220 hostname ESMTP Exim 4.95 Wed, 06 Oct 2021 09:10:39 -0300
2021-10-06 12:10:39 CLIENT -> SERVER: EHLO domainclient.com
2021-10-06 12:10:39 SERVER -> CLIENT: 250-hostname Hello rDNS [IP.IP.IP.IP] 250-SIZE 52428800 250-8BITMIME 250-PIPELINING 250-PIPE_CONNECT 250-AUTH PLAIN LOGIN 250-STARTTLS 250 HELP
2021-10-06 12:10:39 CLIENT -> SERVER: STARTTLS
2021-10-06 12:10:39 SERVER -> CLIENT: 220 TLS go ahead
2021-10-06 12:10:39 SMTP Error: Could not connect to SMTP host.
2021-10-06 12:10:39 CLIENT -> SERVER: QUIT
2021-10-06 12:10:39 SERVER -> CLIENT: 221 hostname closing connection
2021-10-06 12:10:39 SMTP connect() failed. https://github.com/PHPMailer/PHPMailer/wiki/Troubleshooting
Try in phpmailer
$mail->SMTPDebug = true;
To get more information to compare with /var/log/exim/mainlog
