Hi ,My Roundcube is ok but no forward any mail to other mail or Gmail address.
main log
2021-07-12 15:28:03 1m2tdT-0007OK-1l => info <[email protected]> F=<[email protected]> R=virtual_user_unseen T=dovecot_lmtp_udp S=4379 C="250 2.0.0 <[email protected]> +EsaETsg7GAnfgAAUxCO8A Saved"
2021-07-12 15:28:03 1m2tdT-0007OK-1l failed to expand dkim_domain: unknown lookup type "lsearch,ret=key"
2021-07-12 15:28:03 1m2tdT-0007OK-1l =>[email protected] <[email protected]> F=<[email protected]> SRS=<SRS0=MD5N0T=ME=gmail.com=[email protected]> R=lookuphost T=remote_smtp S=4261 H=gmail-smtp-in.l.google.com [142.251.4.27] X=TLS1.2:ECDHE-ECDSA-AES128-GCM-SHA256:128 CV=yes C="250 2.0.0 OK 1626087483 11si10461316qtx.161 - gsmtp"
2021-07-12 15:28:03 1m2tdT-0007OK-1l Completed
rejectlog:
2021-07-12 12:43:52 login authenticator failed for (User) [212.70.149.71]: 535 Incorrect authentication data (set_id=[email protected])
2021-07-12 12:44:00 login authenticator failed for (USER) [200.81.117.10]: 535 Incorrect authentication data (set_id=[email protected])
2021-07-12 12:45:03 login authenticator failed for srv09.siprosa.gob.ar (USER) [181.13.142.141]: 535 Incorrect authentication data (set_id=[email protected])
paniclog:
2021-07-12 15:26:02 1m2tbW-0005QM-Ay User 0 set for local_delivery transport is on the never_users list
2021-07-12 15:26:02 1m2tbW-0005Qk-Bs User 0 set for local_delivery transport is on the never_users list
2021-07-12 15:26:02 1m2tbW-0005R9-Dd User 0 set for local_delivery transport is on the never_users list
2021-07-12 15:31:01 1m2tgL-0000cD-Pw User 0 set for local_delivery transport is on the never_users list
2021-07-12 15:31:01 1m2tgL-0000cs-SM User 0 set for local_delivery transport is on the never_users list
2021-07-12 15:31:02 1m2tgL-0000d2-TS User 0 set for local_delivery transport is on the never_users list
2021-07-12 15:31:02 1m2tgL-0000dB-WA User 0 set for local_delivery transport is on the never_users list
2021-07-12 15:33:38 1m2tir-0002S6-KS failed to expand dkim_domain: unknown lookup type "lsearch,ret=key"
I try :
./build set_fastest
./build set exim yes
./build set eximconf yes
./build set eximconf_release 4.5
./build set spamassassin yes
./build exim
./build exim_conf
Exim version is 4.93.0.4
os centos 7
main log
rejectlog:
paniclog:
I try :
./build set_fastest
./build exim
./build exim_conf
os centos 7
