Not much information is given here.How to fix this issue?
I've already removed the subdomain and disable SSL and enable it again and reissue the certificates but this subdomain dose not show up...
Yes, it end up with the server IP addressNot much information is given here.
When you do this
dig subdomain.server.com A +short
Does it return a valid IP address?
Domain does not exist on the system. Unable to find url.domain.com in /etc/virtual/domainowners, and domain is not set as hostname (servername) in DirectAdmin configuration. Exiting...
no valid domain found - exiting
Any idea why I keep getting this messages?
You disabled SSL or you disabled auto-renew? Normally if you disable auto-renew (there is a button for that), then things will be fine.Disabled SSL on the user/ssl page.
This indeed only works if you this is done at first, so before the domain is removed or ssl is disabled. Weird issue.Now I re-enabled SSL and afterwards disabled auto-renew but that also doesn't seem to work now.
