Server IP blocked
hmaddy
Server ip blocked in same server csf. why its happened and how to find out the reason for this.?
Normally localhost or the own server ip does not get blocked in CSF. Then something must be wrong.
Best is to check out /var/log/lfd.log to see if you can find something there or otherwise the BFM in DA itself, depending on who put the block in CSF.
If with some security settings as in htaccess or whatever redirects to ...... whatever set/configured and those triggering firewall / modesecurity or BMF maybe wrong or in loop redirects could also causing problems
i already checked this and not found any issue or error.?? currently i disabled csf and running server. if i enable csf it will block the access to website/panel and ssh. then i need to disable csf via rescue mode. mod_security and imunify running now.
From what you have explained in the last post here, it seems like your IP that is used to connect to the web panel is getting blocked constantly by lfd/csf. Just for testing purposes, if you are getting blocked after you have enabled CSF, can you access the web panel via a proxy like proxysite.com?
If you have put an invalid authentication such as invalid mail account in a mail client, then fix the authentication because lfd will think that the mail client is doing bruteforce and block your own IP.
