I can not connect email account Thunderbird
  • Thread starter Thread starter Obito
  • Start date Start date
O
Obito
Guest
Hello everyone ;)
I have a big problem with connect to my email via SSL/TSL.
I use thunderbird and can not login to my account. Works fine without SSL !
Thunderbird show this monit : "The configuration could not be verified. Please check your Login and Password! "
It is interesting that Outlook 2019 connects over SSL well .
I testing Thunderbird ver.78 and 52 - no change
I have Letsteecrypt certificates for hostname, domain, mail, smtp, imap.
What log. show You ? Please help me :)
Hello everyone ;)
It is interesting that Outlook https://19216801.onl/ https://routerlogin.uno/ 2019 connects over SSL well .
I got this,...
Don't quote full posts, not even your own, no need for that. We've seen it but this isn't a Thunderbird support forum.
Your issue can be caused by a number of things. If OUtlook is working, then it's more likely a TB or TB configuration issue than a DA issue.
Did you use manual configuration?
Which port are you using?
Did you try the newest version, which is version 91?
