/etc/virtual/domains: Permission denied
gate2vn
Oslo
I tried to rebuild exim, but it is always stuck there
./build exim
./build: line 8932: /etc/virtual/domains: Permission denied
After that, nothing continues, so needed to terminate the process.
The thing is that I am able to edit /etc/virtual/domains, so the permission should not be a problem. Not sure why. Any idea?
Thanks.
I have the same problem.
In the morning I installed the admin indirectly. Unfortunately, now I get the same error. It is possible that some update has been added in the package.
I think it is a bug. In line 8932, the build command was trying to execute the /etc/virtual/domains folder which is not logic
So today they changed something during the day and released an installation package with an error ... Great ... Can someone report them that they made a mistake and that they fix it as soon as possible?
This is what I don't like about it affected the current build. They should test building everything in a server like listing every software in custombuild options.conf and execute the installation in a test server. They will fix this soon I think. Or you can change DA version to a stable release channel to avoid this issue in the future.
Can you recommend any solution to install da for now? Am I forced to wait for a mistake to be corrected?
Same here.. tried an update and got stuck.... :(
Updating Exim
I wrote an email to DA ... Unfortunately, this problem does not bother them...
I am supposed to report this error via a ticket, which is not possible
whell for me it kinda hangs here
2021/11/11 21:40:59 info starting queues
dataskq: command: action=rewrite&value=httpd
PHP 7.4.25 Installed.
Can't they undo the last change? After all, it's not free software. This is blocking the servers!
I'm told it's already fixed and uploaded to the mirrors -- this is definitely nobody else's fault but our own, so we apologize for this. Anyone affected can e-mail sales@da and I'll try to make it right. If someone can also confirm everything is fine now, that would be great.
