IT_Architect
- Feb 27, 2006
With FreeBSD, I can define the partitions in the order I want to. This is advantageous because I can always put /usr and /home last, which means with a VM if I need more space and simply tell VMware to make the VHD larger and then extend into the free space. When I define them in the same order during an AlmaLinux install, /home ended up in the #2 position where I cannot easily expand. I do not want to use LVM and I am using XFS because I deal with hundreds of thousands small files.
