Is there a way on the forum for code areas to collapse?
IT_Architect
Is there a way on the forum for code areas to collapse? When I paste in a large code are, it remains the size of the code area. With most forums, that is not the case. My main concern is that I'm not doing something correctly when I post.
I run or have run IPB, Xenforo, Vbulletin and phpBB forums, i've never seen code tags collapsing. Or I might misunderstand you.
I presume you mean collapsing in width? Might be some mod or adjustment if you have seen that somewhere.
With the current forum software, being Xenforo, you got 2 kinds of code tags. You have the normal code and the icode tags (or rather bbcodes).
This is an example of icode used:
[icode]This is some test in icode[/icode]
which results in:
Then you have the normal code tag, known on every forum software (maybe not the newest versions ipb anymore because they don't support bbcode anymore).
[code]This is some test in code[/code]
which results in
If i use a large code, with the normal code tag, it will be like this:
2021-11-14 05:18:27 1mm6yI-0002n8-6l <= [email protected] H=mail73.sea41.rsgsv.net [148.105.13.73] P=esmtps X=TLS1.2:ECDHE-RSA-AES128-GCM-SHA256:128 CV=no S=246027 DKIM=hbm-machines.com id=542b6f4eac84c4eb84aa4072a.5be836d6a6.20211114041556.88e430e2bd.1bfc17c5@mail73.sea41.rsgsv.net T="Spectaculair veel voordeel!" from <[email protected]> for [email protected]
Is that what you mean? Because I have not see this wrapped in any forum software.
However, if you use the quote tag instead of the code tag.....
then it's wrapping, maybe you mistaken the code tag for the quote tag?
If this is not what you mean, maybe you can clarify?
