 forum.directadmin.com
				If this is the case, shouldn't DA developers remove named service from the interface for ubuntu installations?Does your license match the OS installed?
Because Ubuntu does not use named. It uses bind.
Have a look at this:
and this as solution:
Reload of named.service fails, and multiple named processes on Debian 9
Greetings! I am experiencing a problem with bind not reloading properly on one of our servers. On an identical server, it is working as it should, but it has some strange issues as well. I can't figure out why they are different, or why one of them is failing to reload bind. Both servers have...forum.directadmin.com
You are correct lucian.gratitudeIf this is the case, shouldn't DA developers remove named service from the interface for ubuntu installations?
It confused the hell out of me too until I finally did named -v and saw that it was called bind.
Can you please write the commands line by line for mortals like me and for posterity? Thanks.Did you use the named_service_override and restart directadmin and after that bind?
named_service_override=bind9/usr/local/directadmin/conf directory.
service directadmin restartservice bind9 restartOr just use CTRL+X and it will ask you to overwrite, click Y and enter.Add above command inside the config and use CTRL+O and press ENTER, then CTRL+X to close.
Then try:Failed to reload bind9.service: Unit bind9.service not found.
service bind restartThank you for the drill Richard.Admins should do some learning about basic commands, but I won't refuse help if I can.
From my link in post #2:
To have DA call bind9.service, add this line to the directadmin.conf file:
I presume you know how to edit a file. The directadmin.conf can be found in the/usr/local/directadmin/confdirectory.
Yes it's scary, you have to use SSH.... as root!
Once done, save that file and restart directadmin:
note this command in admin classes as the "service <servicename> restart" command can be used to restart almost any service. As you can see from the following.
Having that said... try to restart bind and see if it works.
Oh yes... do these restart commands also via SSH as root, so you can see any error message if they appear.
If there are no error messages, you should be fine and can restart services (if needed) via the panel again later.
You are maybe the only one, or one of a few, who always explains the circumstances and let people learning too. I was always in a struggle with linuxadmins, who dont teach, and forum participants, who says you must learn linux before. And I guess there are some more. I want to express my deep thanksfulness for this kind of help, to teach how we can learn and beome better ourselfes. Thank you!Admins should do some learning about basic commands, but I won't refuse help if I can.
FYI. My amount of posts doesn't matter. I'm helping here as kind of a hobby. I will never ever forget that new users appreciate all the help they can get. I've been there, that's why I'm doing it. So I won't get annoyed quickly.I know you have over 7 thousand messages on this forum and you probably get bored and many times annoyed with users but don't forget that new users really appreciate the help and I really like the software and the new theme is killing it.
/etc/systemd/system directory (I hope that is the same in Debian/Ubuntu) for the presence of any bind or bindX (where X is some number) file.dpkg -s bind9 forum.directadmin.com
				lucian@server:/etc$ sudo dpkg -s bind9
[sudo] password for lucian:
Package: bind9
Status: install ok installed
Priority: optional
Section: net
Installed-Size: 868
Maintainer: Ubuntu Developers <[email protected]>
Architecture: amd64
Version: 1:9.16.1-0ubuntu2.9
Replaces: bind (<< 1:9.13.6~)
Depends: adduser, bind9-libs (= 1:9.16.1-0ubuntu2.9), bind9-utils (= 1:9.16.1-0ubuntu2.9), debconf | debconf-2.0, dns-root-data, lsb-base (>= 3.2-14), iproute2, netbase, libc6 (>= 2.7), libcap2 (>= 1:2.10), libjson-c4 (>= 0.13.1), liblmdb0 (>= 0.9.7), libmaxminddb0 (>= 1.3.0), libssl1.1 (>= 1.1.0), libxml2 (>= 2.7.4), zlib1g (>= 1:1.1.4)
Pre-Depends: init-system-helpers (>= 1.54~)
Suggests: bind-doc, dnsutils, resolvconf, ufw
Breaks: bind (<< 1:9.13.6~)
Conffiles:
 /etc/apparmor.d/usr.sbin.named 34502426376b676b22e36c63d3cbb5a9
 /etc/bind/bind.keys b6d32dd16ced89ad2b0fdb8f3bee7aab
 /etc/bind/db.0 8aba258068c8c60a7ade3952a285f57d
 /etc/bind/db.127 64f5cf50e8d8192109dad43b779e5e36
 /etc/bind/db.255 8aba258068c8c60a7ade3952a285f57d
 /etc/bind/db.empty 4e7a0ebff9a8936e5a72ec18c0c49214
 /etc/bind/db.local e5d27ead2d238928a08d33c7a7333477
 /etc/bind/named.conf 32be43ecfcb37f69bf967c15c368e184
 /etc/bind/named.conf.default-zones 9fbdc4657090b3b2a45f7e7b8468cf96
 /etc/bind/named.conf.local fb15a27656eafd86ff870effabc72f1e
 /etc/bind/named.conf.options 642e258554b7bd95f4fc71062ca82101
 /etc/bind/zones.rfc1918 d04252b4368b66e28376f92613842888
 /etc/default/named 0fcf4e70d1d3811d13a1f7b52fd5e384
 /etc/init.d/named 2f033c8e309de34d6ae67fca64292598
 /etc/insserv.conf.d/bind9 2f36010c32cff9acc445bb9b577aecf7
 /etc/network/if-down.d/bind9 dd11845d860cd2e30dce8556aa478eb2
 /etc/network/if-up.d/bind9 dd11845d860cd2e30dce8556aa478eb2
 /etc/ppp/ip-down.d/bind9 dd11845d860cd2e30dce8556aa478eb2
 /etc/ppp/ip-up.d/bind9 dd11845d860cd2e30dce8556aa478eb2
 /etc/ufw/applications.d/bind9 ac2316819866611a68b976db9125c9a7
Description: Internet Domain Name Server
 The Berkeley Internet Name Domain (BIND 9) implements an Internet domain
 name server.  BIND 9 is the most widely-used name server software on the
 Internet, and is supported by the Internet Software Consortium, www.isc.org.
 This package provides the server and related configuration files.
Homepage: https://www.isc.org/downloads/bind/
Original-Maintainer: Debian DNS Team <[email protected]> forum.directadmin.com
