ModSecurity + OWASP breaks phpMyAdmin - OWASPv3.4 may fix this
dkzr
The Netherlands
When you enable ModSecurity with the OWASP ruleset the phpMyAdmin (<server>/phpMyAdmin/) is broken by the OWASP rules. In version 3.4 of the OWASP rules a new file and variable is introduced: https://github.com/coreruleset/core...UEST-903.9008-PHPMYADMIN-EXCLUSION-RULES.conf
I have not tested this, v3.4 is not released yet.
Setting `crs_exclusions_phpmyadmin=1` in rule id 900130 should unbreak phpMyAdmin, but how to only set this variable for the main phpMyAdmin?
I've just added the following custom rule. It's a bit crude, but works for me :)
Replace <server name> with your servername.
## OWASP v3.3 phpMyAdmin fix
SecRule SERVER_NAME "@streq <server name>" \
    "id:1001,\
    phase:1,\
    pass,\
    t:none,\
    nolog,\
    chain"
    SecRule REQUEST_URI "@beginsWith /phpMyAdmin/" \
        "t:none,\
        ctl:ruleEngine=Off"
@dkzr , where do we place this, is there a custom.conf file?
Hi Peter,
You can create /usr/local/directadmin/custombuild/custom/modsecurity/conf/ and put custom configs there. I've created a 00-local.conf.main file and put my extra OWASP config options there.
When you rebuild the mod security config you should find that file copied to /etc/modsecurity.d/
As defined in /etc/httpd/conf/extra/httpd-modsecurity.conf the *.conf.main files are included first and then *.conf
@dkzr i have done what you suggested and created the 00-local.conf.main file in /usr/local/directadmin/custombuild/custom/modsecurity/conf/ but when I try to ./build mod_security it only gives me all the options available for custom build. I am a kind of lost here and not exactly sure on how to do it, can you clarify it for me and maybe even in Dutch??
