rowebca
Everything is Ok.
Regards,
George B.
			Regards,
George B.
							No. Is not working, is restricting and after the system will restart clamd and will spike again the server. I already test that information from that page, before to post here.This link will help you to fix the problem:
Fix high server load and memory/cpu consumption of clamd ( ClamAV ) » www.geekytuts.net
When executing top command, clamd was always top on the list. As I researched, there is no way you can limit ClamAV's memory and CPU consumption via its configuration itself. This is how you do it.www.geekytuts.net
Can't helpNo. Is not working, is restricting and after the system will restart clamd and will spike again the server. I already test that information from that page, before to post here.
Regards,
George B.
Ok we to before but with only 4GB we don't do it with scanning mail now anymore it did raise through time , other panel. we where warned there , and don't need for mail on those server , anyway for mail it is hmm but i am no experienced admin. Here we do mailscan virus on local mailservers , and ofcourse even the clients, so makes those less mem server (4-5GB) a lot faster.I am testing right now another approach and I post here the results.
Regards,
George B.
Out of curiosity, how did you install Clamav? I have clamav=yes and clamav_exim=yes in my options.conf but I let my system being scanned by Maldetect, which makes use of Clamav.So I have changed << ConcurrentDatabaseReload >> to << no> in << /etc/clamav/clamd.conf >> and after that I had no issues.
I installed via custombuild (hate this way), and yes I added after manually in /etc/clamd.conf, I just see it that I wrote the wrong patternOut of curiosity, how did you install Clamav? I have clamav=yes and clamav_exim=yes in my options.conf but I let my system being scanned by Maldetect, which makes use of Clamav.
However, I don't have this line in either clamd.conf nore freshclam.conf and my clamd.conf is in /etc/ not in the /etc/clamav/ directory which makes me think you did not install it via custombuild or are you using a distro other than Centos maybe?
Did you add that "ConcurrentDatabaseReload" manually at any time?
I don't mean the custombuild script, just custombuild. I don't know why you hate that way, works great.I installed via custombuild (hate this way)
Yes, the option is there but the default is YES.Please don't quote full posts. we know what we have written and keeps things a bit more clear.
Oke if you added that setting it's fine. Since you wrote you changed it, I thought for some reason it might be present in there by default and I've missed some update.
Thanks.
# Enable non-blocking (multi-threaded/concurrent) database reloads.
# This feature will temporarily load a second scanning engine while scanning
# continues using the first engine. Once loaded, the new engine takes over.
# The old engine is removed as soon as all scans using the old engine have
# completed.
# This feature requires more RAM, so this option is provided in case users are
# willing to block scans during reload in exchange for lower RAM requirements.
# Default: yes
Lol you said you added it. But darn that's odd. I even searched for concur and reload and found nothing.Yes, the option is there but the default is YES.
