DirectAdmin 1.63.3 has been released
fln
Administrator
Staff member
Hi everyone!
We're happy to announce the release of Directadmin version 1.63.3.
This version includes a series of fixes and improvements mostly related to the new DA installation experience. Change log is quite short :D and can can be found here:
DirectAdmin 1.63.3
fln
# Remove dependency on ncftpls in scripts/ftp_list.php
PHP script scripts/ftp_list.php no longer depends on ncftpls being installed on the system. It uses curl instead
This can be messy with the sFTP script from Alex I assume ?
We have re-packed 1.63.3 release build ID 4ec5513397259f8d59a07933283a8cc8dea56d84 it includes a hot-fix for startips script.
Hello. I got errors after updating. Stopped working CustomBuild.
Writes this error
This plugin is compatible with CustomBuild 2.x only.
When trying to do
./build rewrite_confs
Error
/usr/local/directadmin/custombuild/build: eval: line 3517: syntax error near unexpected token `<'
/usr/local/directadmin/custombuild/build: eval: line 3517: `VERSIONS_TXT_<html>
= VERSIONS_TXT_<head><title>404 Not Found</title></head>
= VERSIONS_TXT_<body>
= VERSIONS_TXT_<center><h1>404 Not Found</h1></center>
= VERSIONS_TXT_<hr><center>nginx</center>
= VERSIONS_TXT_</body>
= VERSIONS_TXT_</html>
Got the same "This plugin is compatible with CustomBuild 2.x only." error, but am on 2.x already.
So just I tried doing the
./build all d
Which gives these errors:
./build: line 439: unexpected EOF while looking for matching `"'
./build: line 440: syntax error: unexpected end of file
What could be the problem?
./build all d
Please try:
wget -O /usr/local/directadmin/custombuild/build http://files1.directadmin.com/services/custombuild/2.0/custombuild/build
Hi Martynas,
Thank you for your reply, that fixed the problem.
But now when updating any this error comes up:
ERROR: version of php81 not found in versions.txt!
ERROR: version of imapsync not found in versions.txt!
So I clicked "Update CustomBuild" and after that it was solved!
