Apache goes unresponsive/unreachable during Direct Admin tally update cron run
CAISC
SSH Terminal
Note - I am already running apache 2.4.51, so bug related to apache 2.4.52 is not the issue in my case.
I am facing strange issue, on Direct Admin server Apache goes unresponsive/unreachable randomly after 30 mins to 2 hours (random times) during Direct Admin tally update cron run.
I have to restart apache to make all sites start working. But it keep going unresponsive/unreachable atleast 2 to 4 times during the time tally update cron is running. Tally update cron runs for approx 3 hours on server and during those 3 hours this issue keeps on occuring are random time intervals.
Once Tally update is over all keeps working fine.
It appears server runs out of resources like RAM during the Tally cron run, how do I limit the Tally cron run on RAM usage and make sure it runs for longer duration with low resource usage. Server load seems to be normal during the time cron is running, but I do get very high load warning 1-2 times after the cron run completes. May be its updating the data for all accounts.
Its an 32 core AMD CPU server with 128GB RAM.
This is the cron that's creating problem when running -
10 0 * * * root echo 'action=tally&value=all' >> /usr/local/directadmin/data/task.queue
As per DA support team recommendation I added nice parameter in query -
10 0 * * * root echo 'action=tally&value=all' >> /usr/bin/nice -n 5 /usr/local/directadmin/data/task.queue
But then it appears cron update never finishes, because even after waiting 48+ hours Server Statistics tally is not updated, and shows same old date for "Last Tally Completion"
Appreciate help from experts in this matter.
Just curious how many user accounts do you have on the server?
Also on apache are you using Event as the mpm?
mpm - Worker
Approx 900+ users (1.2 TB DATA),
please note these users were hosted on a low end config cpanel server previously, when compared to this server.
On cpanel server never faced such issue.
What is https://docs.directadmin.com/direct...l-directadmin-conf-values.html#realtime-quota
set to in the directadmin.conf
/usr/local/directadmin/directadmin c |grep realtime
also this one to
/usr/local/directadmin/directadmin c |grep simple
You might try tweaking those.
Any reason your not using mpm_event. I dont have that many users and never used worker.
Also DA is not like cpanel. All new stuff to learn.
realtime_quota=2
Also in file - /etc/cron.d/directadmin_cron
this cron is commented out by default -
#5 5 * * 0 root /sbin/quotaoff -a; /sbin/quotacheck -augm; /sbin/quotaon -a;
Thinking of modifying the cron -
into 2 parts and run at diff intervals -
echo 'action=tally&value=[a-m]*' >> /usr/local/directadmin/data/task.queue
and
echo 'action=tally&value=[n-z]*' >> /usr/local/directadmin/data/task.queue
not sure it will work or not.
simple_disk_usage=0
Previous cpanel server was running on worker, while migrating to DA we tried to keep maximum settings and environment same, as much possible.
So that migration goes on smoothly.
Agree that cpanel and DA are both diff prod, still much to explore for cp admin like us.
We have many servers to be migrated, right now just ironing out some issues that we are facing on DA servers as of now.
Well I am no expert..
I would check php fpm configs and you might like mpm_event better. You will also want to tweak the mariadb configs
You might like parts of this thread
if you dont have opcache on you might try this
Thanks actually we run Cloudlinux and use lsphp by default for all.
Any suggestions for tweaking mariadb configs will be helpful.
Went through all the direct admin parameters that were mentioned, specially -
disabled inode count -
inode=0
plus added few extra in the conf file -
restart_apache_after_tally=1
reload_apache_after_rotation=1
restarted DA.
then again ran the cron -
but no luck, same issue again. This is now becoming a pain point.
Also what is the mpm_worker config
cat /etc/httpd/conf/extra/httpd-mpm.conf
The standard is
<IfModule mpm_worker_module>
StartServers 6
MinSpareThreads 50
MaxSpareThreads 150
ThreadsPerChild 50
MaxRequestWorkers 300
MaxConnectionsPerChild 10000
</IfModule>
Which isn't enough. try something like this. May need to be more.
StartServers 25
MinSpareThreads 50
MaxSpareThreads 150
ThreadsPerChild 50
MaxRequestWorkers 1024
</IfModule>
httpd-mpm.conf is the first thing I adjusted after server setup -
Here are the settings in my case -
ServerLimit 500
StartServers 50
MinSpareThreads 25
MaxSpareThreads 150
ThreadsPerChild 50
MaxRequestWorkers 1000
MaxConnectionsPerChild 5000
</IfModule>
Thanks Brent for the follow up.
tried with combinations -
ServerLimit 1000
and
ServerLimit 2000
but that didn't helped either. ?
Actually load on the server is not that much, almost 95% percent of time
only 20% of CPU and RAM capacity is utilised.
Its a high end server with ample resources and well configured.
Its just this cron that's creates some deadlock during the final stages of computation.
For example What I have seen is -
cron runs for approx 2 hour 45 mins
1st deadlock (Apache unreachable issue) comes after 2 hours mostly, as a remedy I restart the Apache
2nd deadlock (Apache unreachable issue) comes after approx 15 min of 1st deadlock occurence, again as a remedy I restart the Apache
finally after that cron job gets completed and no issue after that.
