Custom Build
hmaddy
custom build updates showing wrong versions.
As per the detailed inspection server installed.
mysql Ver 15.1 Distrib 10.3.32-MariaDB, for Linux (x86_64) using readline 5.1
But now available upgrade version showing different version. check the screenshot
You should have mysql_isnt=mariadb set if you'd like to use MariaDB, it seems mysql_inst=mysql is set now :)
