Apache Down
hmaddy
systemctl status httpd.service
● httpd.service - The Apache HTTP Server
Loaded: loaded (/etc/systemd/system/httpd.service; enabled; vendor preset: disabled)
Active: failed (Result: exit-code) since Thu 2022-01-13 02:13:02 IST; 646ms ago
Process: 3156027 ExecStop=/bin/kill -WINCH ${MAINPID} (code=exited, status=0/SUCCESS)
Process: 3133989 ExecReload=/usr/sbin/httpd $OPTIONS -k graceful (code=exited, status=1/FAILURE)
Process: 3158406 ExecStart=/usr/sbin/httpd $OPTIONS -DFOREGROUND (code=exited, status=1/FAILURE)
Main PID: 3158406 (code=exited, status=1/FAILURE)
Status: "Reading configuration..."
Jan 13 02:13:01 systemd[1]: Starting The Apache HTTP Server...
Jan 13 02:13:02 httpd[3158406]: AH00526: Syntax error on line 18 of /usr/local/directadmin/data/users...conf:
Jan 13 02:13:02 httpd[3158406]: Wrapper /usr/local/safe-bin/fcgid74.sh cannot be accessed: (2)No such...ctory
Jan 13 02:13:02 systemd[1]: httpd.service: main process exited, code=exited, status=1/FAILURE
Jan 13 02:13:02 systemd[1]: Failed to start The Apache HTTP Server.
Jan 13 02:13:02 systemd[1]: Unit httpd.service entered failed state.
Jan 13 02:13:02 systemd[1]: httpd.service failed.
Hint: Some lines were ellipsized, use -l to show in full.
Jan 13 02:45:07 s1.myserver.com httpd[18664]: AH00526: Syntax error on line 18 of /usr/local/directadmin/data/users/aarjishan
Jan 13 02:45:07 s1.myserver.com httpd[18664]: Wrapper /usr/local/safe-bin/fcgid74.sh cannot be accessed: (2)No such file or d
Jan 13 02:45:07 s1.myserver.com systemd[1]: httpd.service: main process exited, code=exited, status=1/FAILURE
Jan 13 02:45:07 s1.myserver.com systemd[1]: Failed to start The Apache HTTP Server.
-- Subject: Unit httpd.service has failed
