Solved Appache not running (AH00526)
SOLVED :)
Removed the ipv6 file in de "ips" folder. Only one ipv4 file now.
httpd service is running again.
Thanks for all the help
I know but i don't see it anymore. :unsure:
Maybe you had removed it already.
Nice to see everything is working again.
I see you put "solved" behind the thread, that is good, but if you can edit your first post... you can also use the prefix solved. ;)
