chanraymond3
- Aug 17, 2006
Do I need to update the OS?
Personally I use Debian (10/buster) as its easy to get used to and (at least for my use case) stable. But Debian does not perform as well as other distros when needing to handle lots of requests or when under a heavier load. So that is something you may need to take into consideration as well.Thanks~Any OS suggestions?
No you're wrong there. Centos 7 is EOL June 30th, 2024. So Centos 7 still has some time.And I hate to say it but CentOS 7 is now also EOF
Centos 7, but until maybe end 2024 (eol in june and end of support also that year I guess).Thanks~Any OS suggestions?
I wouldn't, because Centos 8 is also already end of life since januari 1st so you would be upgrading from EOL OS to EOL OS.How to do it ?
There is no on server path to upgrade CentOSMay I upgrade CentOS6 to 8 ?
There are not really any Choices any more. (that ended on Jan 1st 2022) It is some flavor of Linux. Those choices are RH type or Debian type.what would your choice be, and why?
I don't really think performance on DA has been studied. Most would say RH flavors. If FreeBSD was still supported it would be FreeBSD.OS runs DA the most smoothly (best performance, least problems)
Depends on you view in upgrading based on current choice I think Debian is best for this.has the (historically) best upgrade path?
In my opinion no.Is that a good indication?
If you mean Real Redhat there is no difference other than cost and support maybe.What are the downsides of using RHEL (licensed)
Set up a few boxes on Debian and a few on RedHat. Then let us know what you think.
In my opinion yes, but that is based on the fact that about all professional panels are RH/Centos based so using RH or alike is a good indication for max compatilibity (if issues occur) but not for upgradability for major versions which is indeed better in Debian and alikes.Is that a good indication?
If you are just doing one box. I would use Debian 11.Thanks for the info Brent. I'm not into selling hosting services, it's just a single box.
Not with @Richard G and I... We talk about all kinds of stuff. Agree and Disagree its all good by us..I might start a holy war
